Rust prevention for fresh cut metal?
roc_on_the_rocks
South central Indiana
I built a dolly to store my Tahoe's 3rd row seats with spare material I had laying around and used 1/2" threaded rods cut to length. Given this will be stored in my basement which sometimes is a bit more humid than ideal (new dehumidifier should improve that), I'd like to brush something on the fresh cut metal to prevent rusting. I'd prefer to not paint it if possible, but will if necessary. The threaded rods are galvanized steel and the nut & washer are stainless steel, just because that's what I had on hand.
Would Ospho 605 Metal Treatment be sufficient? Or something else?
Thanks guys & gals!
Spud McGee
Seems ridiculous for the cut end of a threaded rod.
No offense to the OP, but this isn't exactly precision metalwork....
Ridiculous how? Wipe the cold blue chemical on. Then wipe some oil on it. It takes all of 30 seconds.
PCustoms
VT
Because this is what he is worried about:
Whatever paint, spray or brush on, he has around will be fine.
Hell, it's being used indoors. Even if it rusts it will never be an issue. The rough cut is more of a concern then rust for me, with my luck I'd pick up a sliver next time I touched it.
bwringer
Indianapolis
Some way, somehow, coatings will find a way to get onto the cloth of the seats. (Source: the removable second row seats in my van have remarkable powers of long-distance stain attraction.)
Paint the whole thing. Or clear coat or "cold galvanize" if the aesthetics are bothering you. Why the aesthetics of a homemade rack are a consideration in the first place I cannot begin to guess.
Bodj Built
Moorpark, CA
100% agree. Making a mountain out of a mole hill. Literally anything you put on it will stop the minuscule amount of rust. Nail polish, regular paint, primer, spritz of WD40, rub some butter on it, cooking oil, engine oil... literally does not matter. Take a flap disk to those sharp ends, though.
slidehammer
California Central Coast
Thanks guys & gals!
A quick shot of spray paint would be no more expensive or difficult than any method suggested here.
The benefit of paint is that it will dry. Oil, WD-40, LPS-3, cosmoline, etc. will remain tacky.
mogandave
Bangkok
The cold galvanizing spray is nice for bigger stuff, but for small stuff and welds, a little brush (or finger) and ZRC Galvilite I really like. The Galvilite is actually kind of silver too.
We used it for shaft-ends and weld clean-up on galvanized HVAC products. IMO, with welds and shaft-ends a small brush looks much better than rattle-cans, it's cheaper, and you don't have to worry about getting rid of the cans.
crf731
If you are worried about it, go to the store and get some stainless threaded rod to match the stainless nuts and washers. You won’t have to coat it with anything.
R
roc_on_the_rocks
Hey guys and gals, thanks a lot for all replies. Unfortunately - and totally my fault - this thread ended up emphasizing my fabrication skills instead of my core interest here: Rust prevention for fresh cut metal.
Let me explain: When I was young (40+ yrs ago), I used to visit an old school metal fabrication shop where they would squirt spray fresh cut metal with some sort of clear liquid, to avoid flash rust. I have that stuck in my mind all this time and I can't get to figure out what that product was. I suspect it was some phosphate based product, thus my inquire on Ospho 605. Any guess of what that product it could be?
Back to my little project...
Exactly! It's not the launch base for Artemis.
Is the design asymmetric?
Yes, following the attachment points of the seat base.
The picture is deceiving, but yes, it's a sawzall cut, but I filed the ends, so nothing sharp left.
Another approach if you aren't going to change the size, cut it to fit and use acorn nuts
Good idea, but this quick contraption wasn't worth a trip to a store.
Aesthetics was/is definitely not important, and I agree with oily/waxy coatings could end up elsewhere.
The picture was deceiving, no sharp ends left after I filed it. It's a rough cut done with a Sawzall, not a 5-axis CNC.
This is a job for clear nail polish
Bingo! I ended up painting the rod ends with Rust-Oleum® Specialty Appliance Touch-Up paint and realized I need to get some clear nail polish next time I'm at Walmart (making sure no co-worker is looking over my shoulder :) )
mogandave
Bangkok
I love Ospho and have used quite a bit, but it is more a rust conversion coating than a rust preventative for fresh cut steel. Ospho would be perfect for treating cut-off ends that are rusted, or for wiping down/ragging structural steel.
It amazes me that more people do not seem to use it or even know about it. It's been around forever, it's easy to use and it is (or at least was) dirt cheap.
Joemctag
Outside raleigh nc
Agree. Rust there wouldn’t e a problem. BUT…..maybe he’s like me. I work with steel a lot and don’t like to see rust.
I have any to add, storing stuff in basements, especially in corners and low to the floor, surface rust, mold, etc. Steel wouldnyrust heavily. Now, getting wet, like with condensation, then not being able to dry out, yeah, rust is worse. Two pieces of steel in contact, then get wet, that’s the recipe for major, flaking, expanding, putting rust.
