Firefyter-Emt
The negative "bolt" has two wires with clips on them inside the tank (Later moved to the outside of the tank so they are not stored in the water) I did this so my charger never came in contact with the water when in use.
My web-page is here: http://ct-web2.unh.edu/lee/electrolysis.htm
and you asked for a part photo, how is this?
Oh, and I do have a sandblast cabinet too, however there are times you do not want to use sand over the bath method. For example, the water bath will allow small bolts rusted solid to be removed. The sandblast cabinet will not do this for you. I had a Reeves drive motor mount that was akin to a drill press vice in design. The screw and the rods were frozen solid. After a day in the tank, gentle pressure on the hand wheel allowed it to spin free and smooth.
Here is a page about my free sandblast cabinet, click the link to see the after photos.
http://ct-web2.unh.edu/lee/sandblaster.htm
