Rust
frontier52
Good afternoon everyone... new to the forum and the information I have found has been very helpful ( thanks to everyone for sharing ) I've been working on a craftsman saw but the top was rusted pretty bad. After cleaning, grinding and sand blasting their are some serious pits on the top. Does anyone have any good solutions for a repair?
Frontier52
drivesitfar
52: there are a few ways i know of to fix those pits. JB weld is one like Zeke mentioned and i hear Devcon works a little better and is spendier. another way is to weld the pits and grind them smooth or if you have the means to do the method of cutting a new top like Zeke mentioned that sounds like the best fix.
F
frontier52
I like both of your ideas, but the welding one appears to be the most economical. Stick weld, wire weld which would be best?
bmxdad
Puyallup, WA
The top is usually cast iron with aluminum extensions. How big are these pits? If they're not to big just leave them alone. They shouldn't have any effect on the way the saw works, as long as they're not to big ... 1/8" in diameter or smaller. Take a flat file an make sure there are no high spots on the edges.
Mass
Depending on if you are fixing to sell it or use it.
If using:
The top should be flat, not pretty. If grinding and blasting has warped it,
have it ground or planed.
If selling, then pretty is all that matters I guess.
woody 73
The Great State Up North
Not to be the bad boy but in a vintage tool section are we to understand the rust is vintage in some way?:confused:
I am hoping the op is going to show a picture of a pre 1965 saw...
