Hi, Asking about a 2x Clear coat failure using Rustoleum products. I prepped the metal and had a good coat of primer on the parts. According to instructions I used Rustoleum High Performance Enamel aerosol to put color on the job. Several light coats with 20 minutes between coats. Came out great . Let the job sit for 2 days to again be sure paint was dry. I then used a light coat of Rustoleum 2x Clear coat to protect the job. As I applied the clear coat the paint crazed up. I stopped and let everything dry. I tried to sand off all the paint to a smooth finish. No go. So I wire brushed the piece and re primered it again. Here is the rub, I have done the same thing with other parts and they came out great. What could be causing the crazing? Thanks
