rustoleum epoxy shield
cedarcreekjerky
El Dorado Springs MO
Can I apply the epoxy on the outside lip of the garage doors? Also will it adhere good to the outer edge of the plastic floor drain? I have tried searching the forum but keep getting side tracked by all the great info on this site. Thank you in advance.
Strouty
Southern Maine
That is a very reasonable excuse! Welcome to the forum. I am sure someone will be with you shortly.
Shea
California
You can apply it to the small apron of your garage floor that extends past the door, however, it will amber (yellow) fairly quickly from the U.V. exposure. Many times you are better off terminating it at the door.
As far as the floor drain goes, just coat the floor up to the drain. You don't want to coat the drain with it. One trick is to completely tape over the drain and then use a sharp blade to cut the tape around the edges. Once the epoxy is down, pull the tape up and you will have a professional looking cut-in job.
