Rustoleum Floor job in Am
Brentocool
Chicago.Il
Floor if etched and drying. Humid as hell her in Chicago! kinda worried.[/ATTACH]
Edger
Melbourne Australia
After etching slabs normally dry off very quickly. Use a wet vac along the joints to remove any excess water or blow them out with an air hose - make sure no oil of water is in the air supply. If it looks dry it usually is because washing does not allow water to penetrate into the slab, that usually takes a long time to occur.
Brentocool
Chicago.Il
Frigg'n humidity is @ 85!!!!!! Instructions say 85 or lower. I'm gonna wait it out till the sun comes out.:spit:
ishiboo
Oshkosh, WI
Make damn sure it's dry, or you'll have a mess on your hands. One of those things if you fool around with, you'll be very disappointed.
Brentocool
Chicago.Il
Humidity came down and the floor looks awesome! What a stinky smelly mess though![/ATTACH]
Brentocool
Chicago.Il
I learned a couple things doing the job. I used a 12" roller which is a good thing. But i bought a cheap kit because i knew i would be tossing it out when i was done. Well this stuff is heavy and it takes allot of force to spread it.the cheap roller was to flimsy and would bend all over and the roller pad would want to come off . Finally it broke. The longer the pot(paint) sits while working with it the harder it gets to spread. As it is hardening. Also i forgot to mix the sand in the paint when i mixed it...oops! Its a added $$ for non skid. I guess i will have to bring it back. Also the stuff poors off the fumes.. Says they recomend you to power mix the 2 parts together...i dont think its an option!!!
Brentocool
Chicago.Il
Not to happy with the color!!! It looks great but its too dark and any dirt at all shows !!!!!!!!!!! plus it scratches White ???:mad:
