Rustoleum paint recoat time
ishiboo
Oshkosh, WI
I've always had HORRIBLE luck painting things... it never comes out. Part of the problem is my impatience.
Recently, I painted a light bar for my tractor and it couldn't have turned out better. This is the first time I noticed the recoat times on the Rustoleum Pro spray cans are only like 15 minutes. So I shot the primer, waited a bit, then shot 2-3 coats 15 minutes apart. (Or whatever it said the recoat time was)
The finish looks GREAT and it didn't take 4 days to put on 4 coats.
I have some larger projects I need to paint, and looking at the Rustoleum quarts/gallons I notice there is no "recoat" time, but simply a drying time of a minimum of 24 hours. So... with the spray cans I can recoat in quick succession but to spray with a sprayer I have to wait the minimum 24 hours? (Probably more as it's getting cool here)
rlitman
Long Island
The "Pro" line dries much faster. Like Krylon fast.
The regular Rustoleum spray recoat is something like under 2 hours or over 24 hours.
countryroad82
Kentucky
When I spray rustoleum with a gun, my recoat times are normally around the same as the rattle cans. Sometimes though I wait about 30 minutes, it depends on how it dries for me. But it I've sprayed a lot of paint in my time and have a feel for it.
I
ishiboo
Oshkosh, WI
Awesome, thanks!
Yeah, under 2 hours or over 48 on the cans.
Does using hardener change the recoat times at all?
matt_i
Even though its not an official degreaser, I usually swab everything with rubbing alcohol before I paint it. You would be surprised at how much dirt comes off. Contact cleaner which is more volatile might help.
I also let the sun dry the part in question whenever possible with deference to the possible windborne contamination.
Upcoming is a 2 part epoxy paint project for some post brackets. We will see what happens....
I
ishiboo
Oshkosh, WI
I used acetone my last spray bomb and it turned out perfect. Rubbing alcohol would probably work too.
If you don't re coat within 30 min - 60 min you need to wait 24 hrs if you don't the solvent can pop spots in the topcoat.
Gotcha. No, I definitely want to do all my coats as soon as possible so it takes 3 hours and not 3 days :)
When spraying I just wait for it to flash for recoat
Awesome, thanks!
creativecars
Indiana- where horse and buggies still roam
Clean it with a wax and grease remover for auto type paint. For cheaper paints I usually use a cheap thinner to pre-clean, wipe, dry, wipe again. Cleaning needs to remove wax and grease, not just smear it around. Trying to skimp here is where many people have problems.
When spraying without directions I usually have something I had to mask off, make sure you paint onto the tape or paint another part that has similar preparation. Apply a medium wet coat to all, wait 10 minutes and lightly touch the tape or another part. If it is wet liquid, wait another 5 to 10 min. You are looking for still tacky/sticky, but no paint coming off on your finger. Now it time to put another coat on. I like 2 to 3 coats for good coverage and protection.
