That is why the supplier always sends a couple of cans of epoxy to mix together and coat the ends or do touch ups.![]()
Green spraypaint works fine
well i disagree and think it should be blasted clean, powder coated and pin stiripped on the ridges then cleared and polished by 21 year old swedish virgins..........tie wires are to be galvanized dipped and twited no more than 3.3333 turns.........anymore, fire the guy doing the twisting.........support all rebar with cast steel blocks machined to specific dimensions as required to aqllow for an aestehically pleasing look..........remember beauty is skin deep and only you will know how good your rebar is and that's all that counts........
no steel can be touching the soil under the concrete. must be set on plastic chairs, plastic coated wire chairs on concrete bricks
