Rusty water drained from my compressor
MeNeedGarage
Elk Grove, California - Sacramento
I have 5.5 hp husky compressor that is made by Campbell Hausfeld . I bought it at Home Depot years ago. I just moved it to replace the broken belt, and it was full of water. I drained the water that was all rusty. I rinsed it until it came clean, but I'm not sure if I should just get rid of it and get another compressor. Is this one a goner?
LB-1911
Northwestern Il.
Your not the 1st person to defer draining your tank on a more or less frequent basis.
How full is "full of water"
Had any issues with it prior to the belt replacement?
Run it up, shut it off, make note of the pressure and check it in the morning.
EarniesGarage
USA
I wish there was a coating put on the inside when it was manufactured or is there something available we could spray on the inside after disconnecting the air lines. I know there is a product that you can buy from an automotive paint store that can be but directly on the rust and it seals/bonds to it to stop the rusting. It is very pricey though.
I have a new IR 7.5 HP 80 Gallon unit that is about a year old and it has stained the wall orange outside from the automatic drain draining the unit regular.
As far as safety on your tank, It depends on how bad the unit is rusted inside. Find a plumber or a friend with one of those pipe cameras and look inside while it is disconnected to check on its condition. I wish you luck.
taumac
Brooksville, Fl
I'm also with Zeke. I have a ball valve with a hose connected to it for my drain. I use old water bottles and catch the water coming out. By doing this a can see if oil and debris comes out when I drain the tank.
MeNeedGarage
It's been out of use for a couple years. So the water has been setting in it for that long. The petcock doesn't even work. The handle on it just spins around. The tank has never been drained in the past, and I don't think it does it automatically.
Vahispd
SE VA
How did you drain the tank and flush it since the petcock is inoperative? What size is the tank?
As others have recommended, try to put a small inspection camera inside the tank to assess the condition, or have it hydrostatically tested. Definitely replace the petcock and drain the tank regularly if you decide to continue using it.
MeNeedGarage
I removed the petcock with a pair of pliers. I'm not sure what size the tank is. Possibly 25 gallons. I'll get a real answer tomorrow.
CNGsaves
KS and OK
OP . . . buy some pipe fittings so you have elbow and straight length of pipe out to a ball valve that is easy to reach and drain regularly (like daily when you are running the compressor for a while).
Is this a vertical or horizontal tank ??? Pics ??
Spudland_Dave
Maine
VERY Good info...
Guilty as charged...I got a New Puma compressor and just got "too busy" building my shop to drain it on a regular basis...even once things quieted down it was a PITA to get on my hands & knees to screw with the petcock....I finally did exactly what you said (Had the parts to do it all along :lol_hitti) so I did...now I find myself draining the tank almost every time I walk by because its easy.
Only thing I'd suggest...use a brass elbow & ******...so when the water settles at the bottom, which is now the extension pipe, its sitting in brass not steel. Means very little rust going forward.
If you don't want to drain it ALL the time, upsize your drain pipe to 1/2" or 3/4" if you wanted to...
LB-1911
Northwestern Il.
Thank you for providing the additional information.
:see:
If in doubt, take it to the local shop that hydrotests and have them check it. It's not expensive, and the certainty when you fire it up is worth any price.
great white tj
Ocala Fl.
If you don't trust the tank now.. this might be something to think about. I had two of the same husky compressors, each one was in great condition. I did not need a 60gal. 220 volt comp. so I went to a local auction and picked up two older 60gal 220 units that needed help.... no motor or pump ect..... I just needed the tank. I have $120 in two 60gal. tanks less than 5years old. I just moved over the motor and pumps to the 60gal. tanks. Yes it will take a few min. to fill up the tank from the start but it works just as it would if the pump was on the smaller tanks. The cfm does not change, I just have more air. If your pump and motor are good all you need is a tank. put a ball valve on the drain and a 6" ****** and you are good to go...
great white tj
Ocala Fl.
110 volt comp.And yes the blue tank is a water tank....lots of water..
