I bought a Ryobi 10" Sliding Miter saw last Christmas and finally got a chance to use it. I was cutting trim so I swapped the stock blade with a fine finish blade. It works great except it does not quite complete the cut. It leaves about a 16th of an inch on the bottom uncut so when you are done the wood splits or splinters a bit. Is there a way to adjust this as I can see anything that might be adjustable for solving the issue. Just curious if anyone had any similar experiences or has a fix. Way too late to return the saw so need to find a possible solution.
