hi everyone --
Does anyone have a Ryobi 1801M model router?
I just got one (used) , and am trying to figure out how to change bits in the collet
Read the manual, and it says to push in the button to lock the collet
That's easy enough to understand.
But the collet lock is behind a plastic part on the router
that's screwed in.
The manual says nothing about removing that window to get to the button.
The matching plastic window on the other side of the router pops right out
with two tabs.
The instructions talk about how to raise the router in the base far enough to have to depress that collet lock in order to remove the base, but
that's not in the section on changing bits. I can't get it to come
that far apart anyway.
Does Ryobi really mean you have to disassemble the router on that side to change bits?
Seems like they'd mention that in the manual if that's what they expected you to do....
The picture in the manual does show the collet lock on the opposite side
from the pop-out window, but it wouldn't be the first time I've seen
incorrect artwork in a manual...
that's screwed in.
with two tabs.
