Ryobi RY141900 2000 psi pressure washer gasket?
remagenman
I picked up the pressure washer from a re-store for 50 bucks, tried it at home, it sprays but I'm assuming not at full strength because water comes out the sides of the pump when spraying, it's coming out of the face of the pump where the 4 bolts are at.
Question, is this a simple gasket/seal replacement or is it done?
Googling for gaskets and coming up short.
Thanks.
R
remagenman
Update: it was actually a broken bolt, tried removing it with cheap drill bits now a bit broke off in it. Huh!
R
remagenman
welcome to the land of broken bolts with other (hard) stuff stuck in there . I have the Tee Shirt .
what's your plan now?
I bought a cobalt drill bit, smaller than hole, it did nothing. I have a Amazon cobalt set coming today and bolted on the face plate which I will use as a guide to drill a hole size drill bit into. If that works I will tap it. All in theory of course.
R
remagenman
Update: no amount of cobalt drills would work or screw extractors. It took a Dremel with the small stone blue tips and patience to finally wear it down. Damn thing still leaked, took it back.
