Sacraficial Top Coat for Epoxy Flake Clear Urethane Topcoat?
katilicous
Laguna Niguel
I've heard this mentioned before but still can't find info on exact product.
My customer will love when I'm done with the Poly top coat but will want to put a sacrificial wax or finish over the Poly clear.
What should I suggest they use and how often?
LegacyIndustrial
deerfield, IL
You can use an acrylic wax, however will be slippery when wet/oily. Our product is CherryWax, matte or gloss.
Can be re-applied as needed.
K
katilicous
Laguna Niguel
I don't want to make it slippery at all. I read somewhere there is a coating you can top coat your top coat with that acts as a sacrificial coat for scratches and will provide a disposable layer that will protect the poly top.
Maybe I misunderstood whoever I heard about this from...
LegacyIndustrial
deerfield, IL
Wax would be the sacrificial layer, best used where floors are not wet.
Armorpoxy
We find that topcoat is a sacraficial layer. Over time it will wear a bit so just re tpcoat as necessary. If topcoat is maintained the floor should last indefinitely.
