Safe to use old (not used) NM wire?
Truck Addict
I have no idea....I'm lost!
My Father-in-Law just gave me some 12/2 with ground (about 130') . It's new, but was made in 2000. I'm a little concerned because the outer jacket looks like it is a pinkish creamy color. I didn't know if the sun has gotten to this or if that is even a concern. I don't know if he had it stored inside, outside, etc.The color is uniform , so maybe this is just the color. I'm used to seeing it in yellow. The wire says Romex NM-B with ground and then says Extruder. The lettering is not faded and is a green/blue color. I don't want to turn down free wire but just wanted to make sure that the jacketing isn't going to fall apart, etc. when I put some staples over it etc.
Thanks,
T A
6768rogues
Western NY
Wire from 2000 is not all that old. If it is not brittle, I would probably use it. NM is not sunlight resistant, so if it was outside it could be compromised.
T
Truck Addict
Thanks guys. Looks like I'm using it. Dumb question......was there any code changes in wire spec since 2000? Since I have to get my elec inspected, am I okay using non-yellow, etc NM?
Thanks,
Jerry
KenC
oklahoma
Check with your inspector. The code mandated yellow is for the ease of inspection. The guys can tell at a glance what gauge the wire is by the color. But, our local guy doesn't care. I suspect most won't, but best to ask.
Charles (in GA)
50 mi south of Atlanta
Its marked MN-B which is, I think, current version of the wire, with 90°C conductors. As long as the markings are readable, there is no real reason to not use it.
Charles
T
Truck Addict
Thanks guys. I ran that wire today. Still have a few more lights etc to wire for. It's a good thing I'm not an electrician......I totally missed the boat on how much wire I needed. Should have bought more up front.....it would have been cheaper even considering the freebie I just got. Live and learn!
Jerry
