Safety Disconnect
ltusler
Greenfield, MN
My in floor heating boiler is a Seisco 9k unit. The specs call for a 50A x2 disconnect. A couple of years ago I notice the 60A one that was installed had melted and was making crackling noises. So I replaced it with a like unit. Now its doing the same thing again.
So do I need to install a larger one, or is there a problem down stream from it?
TIA!
This is the one I installed.
https://www.menards.com/main/electr...48-c-6435.htm?tid=-5705665774111765499&ipos=8
Max
Georgia
TIA!
If you’re asking if a 60A disconnect should melt every couple of years the answer is no. The 60A disconnect should handle 50A essentially forever.
As @couch67 suggested I’d check the connections. I’d also use a clamp on ammeter to figure out what the load current is and then debug further as needed.
Max
Georgia
Those a/c disconnects don't hold up to heavy load. They claim 60A rating but I consider it 30-40A max.
Get a real safety switch.
I’m not disagreeing with you or your experience. But if the disconnect can’t handle its rated load, then either the mfg. or the testing authority screwed up.
sparky 1971
Central Iowa
TIA!
That's a cheap AC disconnect. Get a real disconnect. I use Square D almost exclusively, but there's nothing wrong with Siemens either. Menards carries Eaton, but the only type they have are fused. Go to a supply house and get one. I linked a Square D just for visualization and a reference part number. it shouldn't cost as much as the site says, I paid $86.75 for one yesterday.
EDIT; I screwed up. The link is for a three pole disco. The two pole part number is DU222. I forgot that I wound up getting a three pole because the supply house was out of two poles. And used the same part number from my ticket.
Bert_
NW Iowa
Compare the inside of a 60A ac disconnect to even a general duty 60A safety switch.
The ac disconnects also cost like $12. They can't achieve that price without cutting every possible corner.
tool_scrounge
Southern California
+1 on a quality disconnect. We once had a 100A heavy duty disconnect for the garage 50A service. Never an issue, other than you and your close neighbors could hear it being actuated!
L
ltusler
Greenfield, MN
Thanks all. I bypassed the safety and wire nutted the leads. It was only the black lead that had a problem. The system has been running and the L1 and L2 are not getting warm at all. However the unit is not heating. I can see each heater element cycling from 0 to 18 amps, but the water is not getting warm. So I wonder if the unit is broken, its not showing any codes on the LED flasher.
Metal-Marc
Foothills of the Adirondacks
Bypassing safety switches is the way to go.
Worst case scenario is you burn the place down?
sparky 1971
Central Iowa
How is bypassing a non fused disconnect going to cause a fire? The wires being nutted together is better than the disconnect that was there before. I've done it many times to get something working while I went to get parts to make the proper fix.
sparky 1971
Central Iowa
I needed something to do and those people have more money than they know what to do with and I decided I wanted some of it I just stopped and gave them my card, then told them that the disconnect for the heat pump might be worn out. If they ever find out the truth, I'm doomed.
mike93lx
Richmond, VA
Lol. I bet you keep that burned out one on the truck and quickly hang it when the homeowner isn't looking
