600SL
I am interested in running 240V to my lathe and splitting off 120 to an additional duplex receptacle to run accessories.
There are safety switches and main lugs as shown below.
In this scenario I would need to put two wires into each load terminal screw. I remember having a home inspector telling me that that was a no-no. but yet I see it done all the time.
Would either of these work. I would prefer to use the main lug CB style because it is cheaper and more compact.
An aside question why are all the AC service disconnect now use a removable bridge instead of a knife switch. I hate those.
It I go with the safety switch will I need a three pole or can I use a two pole and just splice the neutrals or install a neutral bar.
Also does the neutral get bonded to ground or not.
https://www.platt.com/platt-electri...3-Pole/Eaton/DG321UGB/product.aspx?zpid=10561
http://www.homedepot.com/p/Square-D...door-Main-Lug-Load-Center-QO2L30SCP/100157760
As far as rationale u would have to research the code making panel that came up with that code.
