c5golfguy
Bought this 120hz 1080p Samsung 46" LCD about 23 months ago. Had picked it up at Circuit City on a steal thanks to a deal I found on www.slickdeals.net. Needless to say, the warranty was up. Last Wed. the tv started clicking and having an issue on turning on. You could hear a switching sound, that sounded like a relay was clicking. Started doing some research and found out that the capacitors were to blame. So, here is a good documented process of replacing the capacitors. Hope ya'll could use this sometime in the future for your flat screens you got in your home or garages.
Took a picture of where everything went in case I needed it.
Here, you can see the caps bulging. These caps were 2200uF, 10v and 105c in temp. I upgraded to 16volt caps so I don't have this problem again, since the tv operate at 13.1volts.
Another of the caps pointed out by the arrows.
New caps installed. You can see the difference in quality of the new caps compared to the old blue crappy caps.
Another picture of the finished product.
Full picture of the circuit board.
Finished solder job. The negative side of one of the caps solder job wasn't that great of a job. It's somewhat boogered up in my opinion, but it works.
The board mounted back into the tv and ready for the cover to be put back on and try it out.
She's alive and working great. No more problems starting up.
The radio shack thing I got was adjustable 20/40watt. I saw different size tips on the rack. I don't do this very often, so I thought the iron was ok. I knew my Snap-On butane soldering iron I used for car audio stuff for the last 15+ years would be too hot.
