burninghXcsoul
I have a sand mound system at my house. On the top of the sand mount in each respective corner there are 2" PVC pipes with screw caps on them. Apparently one of them is loose maybe after being run over by the riding lawn mower some I'm not really sure.
I saw that it was out of the ground and that there was water coming up out of the hole in the ground that definitely had that sewer smell. The pipe looks to have come loose about a 1 foot under the surface as there looked to be the purple pvc glue on the end of the pipe. I'm assuming the glue gave up the ghost?
I always thought the pipe was loose and wobbly in the hole but I've never seen water or smelled that smell before. We have had a ton of rain lately in SC PA so I dont know if thats it or what. I'm assuming that just by gluing the pipe back should fix that problem? Any help you guys can provide would be appreciated. Thanks.
