jtyson
Hoping you guys can help me figure out what is going on. I snagged a little pressure pot style media blaster off craiglist. Guy said it worked perfectly, but didn't have a compressor to test it with. I should have turned away, but, stupidly, I did not. The picture I attached is the type it is, but much older and uglier.
This thing was caked with rock hard sand. After about 6 hours worth of cleaning, it flows now. However, when hooked up to my compressor, all the valves open, when I open the nozzle to spray, it POURS media out at the rate of about a cup every 3 seconds. I have plenty of air being supplied. If I close the nozzle, detach my air supply, air and sand will shoot out the inlet, at a rate that would be acceptable for blasting.
I'm confused. Could my hose from the siphon be too large? Or the ball valve? It is going through a rather small nozzle, but still, it won't take even the smallest amount of surface rust off.
