I just finished patching a 27"x14" hole in the garage ceiling. I had to cut this section to remove/replace insulation and clean out the mess caused by a leak above. All buttoned up. Just applied the last coat of compound. I hope it will be dry enough to sand tomorrow.
I have a palm sander and I also purchased some 3m foam block with the abrasive integrated.
Can I use a palm sander (unside down) to sand the ceiling. Trying to contain the dust. The palm dander had a catch bag but not sure if it works inverted.
If the palm sander would work, What grit paper would you suggest starting with and finishing with?
Thanks.
Thanks.
