Sanding paint on concrete floor
nm2
Canada, Quebec, Shawinigan
Hi,
My workshop concrete floor has very beautiful with a glossy finish. This concrete was polished while 18 hours when I create my floor (12 years ago)! 6 monts later I painted this floor with an Oil Alkide paint for floor !
Now, I would like remove this paint but I don't want damage my concrete. I tried with my grinder/polisher 0-4000 7inch with a my diamond disk 7"... work fine to remove paint but this damage my glossy contrete !
I would like remove this paint with a sanding machine and sand paper ! I don't want use a diamabrush (too expensive) and probably that this will damage my concrete ! Note that my workshop is in my house with a young baby, so I can't use as chemical product !
What machine, tools, sand paper, grade paper, can I use to remove a paint only ?
hayhauler71
MN
interested as well as I painted a truck in the garage and the over spray ate into the concrete sealer.
Bondo
Greenfield, Maine
Ayuh,.... Rent a rotary commercial grade floor scrubber/ polisher,....
The pads for those are like the ro-loc pads used mechanicin',....
They'll scrub yer paint off,...
Go to fine pads to buff out the finish after,....
N
nm2
Ayuh,.... Rent a rotary commercial grade floor scrubber/ polisher,...The pads for those are like the ro-loc pads used mechanicin',
Friday, I called my local rental Cie, and said me that our PAD cannot remove paint on concrete floor.
Can you give me a link for this PAD, able to remove paint ?
Thanks
N
nm2
Hi
Can I use this machine 17inch (300RPM):
With this PAD:
Plus sand paper 17" diameter GRIT40 to remove paint ?
Thanks
benwah
Lakewood, Colorado
40 grit is pretty dang rough. I can see you eating up concrete with that. You can start with something safe, like 80 or 100, and work your way up/down from there.
