Sasgen Derrick Winch
N
ndnchf
Fredericksburg, Virginia
I get on G503 sometimes, but generally hang out on the CJ2A forum and several Willys facebook groups. That fastener kit is awesome - great find! The hand crank siren is fun for the kids at car shows. I let them crank it, they love it.
The square ends of the shafts are 7/8". In the photo I'm using a 1/2" drive 1", 12 point deep socket. It fits perfectly on the 7/8" square. But I realize the 12 point doesn't have much bite on the four corners. I've located online 7/8" square drive sockets with 8 points that have a much better bite. The ratchet is a big Chinese 3/4" drive with an adapter to the 1/2" drive socket. I've been debating weather to use the big 3/4" ratchet or a 1/2" drive. But I think I'll go with the 3/4" for the addition as l leverage. Surprisingly, it will fit in the jeep's toolbox. I need to order a 3/4" drive square drive socket, then I'll be all set.
I kinda sorta consider it a prized possession, but I might could be talked out of this Made in the Good Ol' vintage jobbie for such a worthy cause. It's a massive (20" long, 1 inch thick, 7 lbs) Lowell Wrench Co. No. 3-1/2 ratchet with a sort of blue-gray enamel finish and some exquisite markings on the head. The second patent number on the right there (2,003,348) dates to 1935. It's 3/4-inch drive, reversible (believe it or not, that knurled knob on the end is the switch!), and female. You would need a 3/4-inch male drive plug to drive a 3/4-inch drive socket or a 3/4-to-1/2-inch drive male-to-male adaptor to drive a 1/2-inch drive socket. PM me if it really strikes your fancy.
N
ndnchf
That is really sweet Lugz! I wouldn't want to take one of your children. But I appreciate the offer. I have something in the works that I think will look good with it. Give me a few days and I'll post it :)
Loose Ctrl
Upstate SC
Very nice winch. I see it's a one-way model. It puls and then free spools out. I'll be looking for something similar when I build my boat. I may round up some parts and make one. I'll be using 200 feet of 5/16 SS chain connected to a plow type anchor.
2oolhound
BC Canada
Nice work!
It's similar to my Beebe Bros winch with the direct drive in the centre of the drum and the 5:1 ? (or there about) drive gear. You have to be careful when it's under load and you want to spool out because all you have to ease the tension out is the brake band on the side of the drum. Under a heavy load it will be all you can do to hold that drum with the brake lever. It's good you have a ratchet to drive it because a crank handle could easily crack your jaw if you found you couldn't hold it with the brake lever. Be very carful specially at first before you get used to it.
Lug, I had a ratchet like yours that was 1" drive but I sold it cheap to a buddy a few years ago. (it was military green too).
N
ndnchf
Good point. I relined the brake, but not sure yet how effective it is. One feature I like is that when winding in the cable, the pawl stays engaged. It just rides over each tooth on the bull gear, dropping into each gear tooth root as its wound in. So the load can't slip back out. A simple but effective design.
N
ndnchf
Here is what I've done for a ratchet. I stripped, bead blasted and painted the 3/4" drive, 19" long ratchet to match. But I cannot find a 3/4" drive, 7/8" square drive (8 point) deep socket. So I'm using an adapter to a 1/2" drive socket. I'm still not completely satisfied - I don't like using an adapter. I just ordered a 1/2" drive, 24" long ratchet to eliminate use of the adapter.
N
ndnchf
Ah. I thought you were using a deep well to clear the handle away from the winch for cranking. Looks great, ndnchf! Nobody as obnoxiously picayune as me will even notice that it's a modern Chinese product now that it's painted! :) (I admire the Civil Defense theme.) If the adaptor is not wobbling and you have a firm connection from the drive stud all the way through to the shaft, it looks great, but I understand your concern.
N
ndnchf
I was not satisfied with the 12 point socket for connecting to the square shaft. Not being able to find what I wanted - I made it :)
I bought an old Snap-On 8 point, 7/8" square drive socket. But it wasn't deep enough. So I cut the square drive end off, then welded it inside a 3/4" drive, 1-1/2" socket. This gave me a square drive for a firm grip, depth enough to go full onto the square shaft and 3/4" drive for my heavy duty rachet.
ViceRoy2030
Picked up a Beebe 2 ton this morning at a garage sale. It operates perfectly, good brake, springs all work but paint is a bit hideous. This will be a resto for sure and I believe it will also be a user, to lift heavy vises in my garage :cool:
ViceRoy2030
Awesome video, love the old tools of the day. That winch requires ZERO battery/electrical power!!! It's no wonder they were always thin back in the day. Thanks for the video!!!
Farmer J.
UK, Cornwall/Hertfordshire.
Thanks for posting the video, just the thing to watch with a coffee on an English rainy windy Sunday morning!
It reminded me of something i had forgotten.. I have a PTO gearbox and winch for a Land Rover sitting in storage in my old Nissen Hut all ready for restoration..! :D
ashlinero
I got it broken down as far as possible. Bead blasted the removed parts. The winch is in the electrolysis tank. It will take a couple days to get derusted. I heated up the bent brake lever in the forge and straightened it out. Drilled out the rivets of the brake lining and got the brake band back close to round. Making progress!
My dad may have made that winch. I am almost positive he designed it. He worked at Sasgen for 40 years, and they closed when he retired. The owners are no longer alive.
