Saved from the scrapyard...
nickjj
Bournemouth UK
BP oil pump, Woden Vice and Van Dorn (?) Grinder
Gems or junk?
Fretters
South Yorkshire, England
All worthwhile keeping. Van Dorn was taken over by B&D donkeys years ago, which is why old Van Dorn and some B&D grinders look the same. Woden vice, if it's in usable or restorable nick, definitely a good vice. The oil pump is handy to have if you need one.
N
nickjj
Bournemouth UK
Woden Vice, needs a coat of paint.
2oolhound
BC Canada
Yeah, you ****.
The woden has a quick release so you're not spinning the handle for endless minutes every time you want to re-adjust.
Fretters
I think you'll find that vice is cast steel rather than cast iron, so more resilient to a sound thrashing. Still not advisable to inflict such upon it though. :D Looks like the QR needs setting up properly too. That lever is 180 degrees out.
N
nickjj
Bournemouth UK
The handle's been replaced by a big long bolt, so it may have lead a hard life, found in a workshop nobody had been in for 15 years.
Fretters
Probably somebody bent the original whilst using a length of pipe. That vice seems to be in pretty good nick, judging from the available photo's. You've done extremely well with that one, if the top, slide and QR mechanism are all as sound as the rest appears to be? 4-1/2" or so on the jaw width, is that one?
