Saving an old Craftsman Floor Jack
astroracer
Mid_Michigan
A friend of mine broke the diecast universal joint in his Craftsman floor jack. He couldn't find a replacement universal so, in looking at the broke pieces, I figured it wouldn't be that hard to make a new one out of steel.
The pieces aren't that big. Only 3/4" in diameter. All of the parts after dis-assembly.
I found a piece of 3/4" diameter steel in the drop pile.
I cleaned up the OD in the lathe, faced off the ends and drilled out the bore's for the mating parts. Test fitting the parts.
With that done I clamped the piece in the vise on the mill and machined off both sides.
With that done I picked up the ends and center drilled for the pin holes.
After drilling out the pin holes I flipped the part 90 degrees in the vise and hogged out the center portion with a 1/2" end mill.
After some deburring and cleanup.
I split the piece into two.
After rounding over the cut ends and a bit of assembly and I had a new U-Joint!
This was fun project and it will save an old jack from the scrap pile. :)
Mark
Ponchoguy
Wow. Good work. I want to say that U-joint looks like a #248731 for a Walker jack. Some Sears jacks were made by Walker. They were green and I believe the model # prefix was 626 if I remember right. The 328 model prefix jacks were Japanese made Yasui units.
txvwnut
Bedford, Texas
Great job. It's nice when you get to bust out on the machines and do something pourposeful and fun at the same time.
sanddan
Oregon
Very nice! Did you peen the ends of the axle?
I have one of the green Craftsman jacks, should be close to 30 yr old by now and still used all of the time.
