Sawmill
R
RivennHewn
PNW
Pleasantly surprised at the noise level with the machine cutting and the dust collector going.
R
RivennHewn
PNW
Going to bite into this crotch.
Pretty low expectations, but ya never know!
R
RivennHewn
PNW
Not great, not bad.
It’s Pine, and the pitch is flowing 😬.
Cut a few cookies too.
R
RivennHewn
PNW
How did you hold it in place, we have a cherry sump we would like to slice up
I have a table fitted to span between bunks, then I screw stop blocks around the base and some 45 degree blocks that go up a bit higher to stabilize the piece.
No pics of the setup, but I’ll grab some later.
R
RivennHewn
PNW
Here’s an attempt to get this thread back on track
Offcut from the cookies was so thin the sunlight came through it.
I’m impressed at how precise the mill can be if you set it up properly.
R
RivennHewn
PNW
Here’s a pic of how I stabilize for cutting cookies.
I start with longer ones that keep the top from wiggling, then cut them down as I take the top off. Just remember to remove the screws before you cut into them.
It’s amazing how much pull the blade has.
It can move a 500 lb log if it’s not secured.
R
RivennHewn
PNW
We cut some cookies and they warped fairly quickly
Yes, they tend to dry too fast, which leads to cracks and warping.
Stickered and weighted, out of sunlight and heat sources gives a better chance, but they will still warp and crack.
I built a table awhile back. Big, thick Elm round.
Sat in my shed for years. It cracked while I was installing the last leg into the mortise.
Usually it’s about what to do when it cracks, as opposed to getting them not to crack.
R
RivennHewn
PNW
Running some channel wood over my dad’s ‘ol mid-sixties Rockwell jointer
Model No. 37-220
Serial No. CZ7985
Just in case one of ya just feels like looking it up and dating it for me👊
R
RivennHewn
PNW
So, if I’m reading this right, and, more importantly, understanding, this ‘ol jointer is a 1963 version.
So smooth, she just hums and sings.
R
RivennHewn
PNW
I do agree that the jointer is a beauty.
I do love vintage cast iron machinery!
I inherited it from my Dad, so I’ve got nothing except a little cleaning invested in it.
Thinking about a bit of an upgrade.
John McA
Pasadena
Just completing this upgrade on my old deco 6 in Delta. New bearings also. Has blade also set for the rabbit function - hadn't thought about that, so I get to see how that will work. I have cut some serous rabbits in the past, not sure how 1 cutter blade per rev. compared to 3 is going to work well.
I did my 12in planer and it turned out nice and quiet.
Good luck,
John McA
R
RivennHewn
PNW
Good luck,
John McA
I don’t believe they’re intended for rabbiting.
Let me know how it works for you.
Do you have the cast iron base? My old belt sander had the cast iron base, and I thought about putting the jointer on it. But I ended up selling it with the sander.
Treeman
I have never used it, but there is a chemical called PEG that you can soak wood cookies in that supposedly stabilizes it to prevent cracking.
PugetDude
Superstition Mountains, AZ
PEG was used in the restoration of the ship and the artifacts found on the submerged Steamship Arabia that went down in the Missouri River outside Kansas City in 1856; it was recovered in 1988. Fascinating museum in KC with detailed technical information on how PEG stabilzes the wood cells as they dry out.
PEG was also used on the Vasa in Sweden, with bad results.
The ship was rediscovered in 1958, raised in 1961, treated with preservatives and finally put on display in the Vasa museum in 1990. The museum preserved the ship with polyethylene glycol (PEG) in a thick, wax-like preparation dissolved in water and sprayed onto the wood for 17 years. Concerns about deterioration arose, and the authors set out to determine the effects of PEG, iron from nails and rivets, and sulfur from decaying bacteria on the wood's strength.
From
R
RivennHewn
PNW
At current HD pricing, here’s a $500 stack of 1x6x 8.5’ free channel wood.
Old growth Red Cedar.
Going to be an accent wall in the wife’s master bathroom.
R
RivennHewn
PNW
I have a couple boards with split ends.
Time for some glue-up.
R
RivennHewn
PNW
A little more F’n around in the shop this afternoon.
Ran some little root slabs through the planner.
Not sure what it’ll become, but it’s kinda interesting.
R
RivennHewn
PNW
I love night fishing!
Pulled in a monster tonight.
51’ long
24” diameter
950 board feet (estimated)
My calculator says it would be 7500 lbs.
But that’s freshly felled.
After soaking for God knows how long, it could be well over 10,000 lbs.
I secured it to the seawall tonight. Will assess condition tomorrow.
R
RivennHewn
PNW
Last night’s log is about as ugly as I’ve seen.
Full beard of barnacles, mussels, and weed.
But I could tell by the way the chainsaw was grabbing all the way through that it was going to be good!
John McA
Pasadena
I will. The original did so very well. I ran 600 lf of fir 1 inch by 3/4 sectional rabbit thru it, without issue. It has the CI deco base. Love those bases.
R
RivennHewn
PNW
One of the highlights of owning a mill is pulling the piece off from the 1st cut, and seeing what you’ve got.
Tonight was kinda awesome.
Shipworms are disgusting little buggers, but make for interesting slabs!
R
RivennHewn
PNW
Holy Moly that’s a lot of holes! Will the whole log be this holely or is this hole condition wholly confined to the outside of the log?
Seems they like to eat.
They must use their poop, and some excretion to line the tunnel walls. It makes tubes. The tubes remind me of a meerschaum pipe. They are quite substantial for how thin they are.
I cut the part of the log that was submerged.
I’d like to think I’ll get some clear wood too.
