Sawmill
Walkers
Cave Creek Az
Nice I have a guy in town that has a band mill when I need a lot of wood. I mill with a more primitive setup the Alaskan chainsaw mill it works great for custom cutting and getting to a hard to reach spot I just mill on the spot and load the truck, it is hard work though.
I dry my wood in a dehumidifier kiln for my furniture.
With that log on the bottom you could cut out a bunch of 2x4s and sell them to Home Depot
R
RivennHewn
PNW
That’s @ranger_the_newfie (he’s got his own Instagram)
He’s my 3 year old goofy-assed Newfoundland.
Just got his 36,000 mile check up at the vet this week. Vet says he’s in perfect health.
He is on the smaller side for the breed, weighing 137lbs.
But, the bigger they are, the more problems they are prone to.
Fatboy148
Beautiful puppy! I hope you get a ton of years out of him. We were lucky, our TM went for 15.5 trouble free years then she started having some issues in her get along. Got so she had difficulty on the tile floors with her back legs wanting to give out on her. Hardwood, carpet, anything else but tile, she was fine. It was time. :(
R
RivennHewn
PNW
Always a hard day when the time comes
R
RivennHewn
PNW
R
RivennHewn
PNW
Question for y’all:
They show the cutting head locked down to the trailer (for transport) almost to the end of the trailer, well behind the axle.
While I’m sure they did their research, I can’t help but wonder if it wouldn’t be better to set it up at, or in front of the axle.
Since I have to drill the rails for the lynch pins that lock the head to the trailer, I can do it anywhere along the trailer.
would love to hear your opinions.
LXCam
Just Forward. The last thing you want is a tongue lite issue.
Just looked at the picture and didn’t realize how far back the axle is. Without the head what do you estimate the tongue weight being?
R
RivennHewn
PNW
From the axle forward, I’m guessing 1500 lbs.
R
RivennHewn
PNW
Doing a little math.
Total weight is 2K lbs.
Instructions says to lift the assembly with equipment capable of lifting 1000 lbs.
So the total trailer is 1000 lbs.
2/3rds of that is in front of the axels.
so you have 660 lbs in front of the axle, and 1340 lbs behind the axle.
(Approximately)
R
RivennHewn
PNW
Getting down to the smaller items on the list!
squared up the log stops.
Installed the cam clamps.
Torqued a bunch of M12s to 93 lbs.
Drilled the frame for the lock-down pins (I went with the manufacturer’s spec for location, for now)
Secured/adjusted the log scale/ indicator.
Installed the fenders.
Adjusted the throttle cable (rough).
Installed a door clamp/latch on each door.
Had a pFriem Pilsner for lunch.
All while under a tsunami Advisory 😜
