thinktwicez71
I got a steal on a Saylor beall 4500 air compreasor , no motor , but with the big air cooled aftercooler for $100. I got the new motor and .motor starter for it and it works great . Being a picky person I wanted no leaks on it . So out comes my bottle of soap solution and it leaks air at the gasket on the head/ valves surface , at both gaskets at the intercoolers and at the 4 holes where the valves go , plus at a big check valve . Can i get a garloc sheet and make my own replacement head gasket and intercooler gaskets ? The hard part seams like the valve seals or gaskets are round and would need to be factory ordered ?
120 gallon tank pumped to 120psi will be down to 30 psi in 48 hours . Takes about 4-5 minutes to fill .
