Saylor Beall 705. What does the unloader do?
frascati
Will someone please explain in complete detail. what a pump mounted (as in the case of my SB 705) unloader valve is designed to accomplish and where it is plumbed?
How does it differ, if at all, in purpose from the pressure switch unloader valve. And are they plumbed differently?
Thanks.
zkling
On pump unloaders have multiple designs but they all do the same thing, that is they allow the pump to get a running start before it has to work and compress air. On larger pumps with heavy fly and large diameter pistons, that is alot of inertia for the motor to overcome from a dead stop, adding in the force on the pistons from compressing air during this cycle can be just to much for a given motor size. The unloaders allow the pump to reach running RMP before compression of air into the tank happens. On the Saylor Beall, IIRC they use a centrifugal unloader, where the pump has to meet a specific minimum RPM before it will start compressing air and directing it into the tank. Other makers use different methods for unloaders. Quincy for instance uses a hydraulic method that sens oil pressure in the crank case.
They are plumbed into the tank to sense tank pressure, sometimes directly, sometimes through a control valve circuit. Sorry, but I'm not familiar with Saylor Beall pumps to know for sure what all yours needs to go through.
The after pump unloader, does the same thing, but instead takes residual pressure off the exit valve and plumbing between the pump and usually in tank check valve. Again different makers use different methods to accomplish the same tasks.
b-body-bob
Almost Heaven
FWIW, My Champion has a pump-mounted centrifugal unloader, and it plumbs into the 2nd stage outlet manifold so it bleeds off any pressure between the pump outlet valve and the tank check valve. The air exhausted by the unloader is piped to the 1st stage inlet manifold so it exits via the filter.
