TonyJ
After some long searching I came across a used Saylor Beall 707 pump on the ol FB marketplace. Pump was missing the flywheel and the exhaust manifold but over all looked great in the pictures. Buyer said he bought it in the same condition for a build but ended up being more than he wanted to put into it but said “seemed” to build air by turning it by hand.
So for $200 and a 4 hour ride, 2 both ways I took the chance and went and looked at it. Got there and looked it over. I hand turned the shaft while I blocked the intake with my hand and it sucked my hand right up tight. It also did the same on the other cylinder too. So that was a plus. Oil was clean and intake valves were also clean. I really don’t think this pump had very many hours on it at all.
I already had the needed flywheel and also a 10hp single phase motor. So I ended up making me a shopping list which didn’t end up too bad I don’t believe.
Needed
2 - pop off valves, one for each after cooler 1/8 npt 70psi
1 - exhaust manifold
1 - 200 psi 1/4 npt pop off valve for exhaust manifold
2 - 1” air filter assembly’s, both covers were missing
1 - 7 3/4 2 groove pulley for the motor/with sheave
So $257 dollars later I have all of the needed parts ordered except for the necessary plumbing parts to get it connected to my tank
I will be removing my Quincy 230 from my tank and installing the SB after I get all the parts and hopefully will never have to wait on air again. The Quincy is great but at 100psi max pressure it struggles when it comes to using angle grinders and 1/2 impacts for extended periods so I will likely sell the 230 to recoup some of my investment on the SB
Tony
Needed
Tony
