TL95SVT
Hey Guys,
For the last 10-15 years i have been fighting with air compressors... like most do. Never enough air... and the air you do have is watery/greasy. I have been sand blasting and need more air. I do all my work in my shed and have limited power... so my only option is gas. I currently have a 5hp Honda Wheelbarrow Compressor to blast with. I can blast wide open and it fluxuates from 60-80psi. I actually bought an extra 10 gallon storage tank hoping it would help... didn't. I then added a small 2hp compressor to the setup.. so a 5hp gas and 2hp electric feeding into the storage tank. Still not enough. I bought another 5hp gas compressor... Have 2 5hp gas compressors feeding into the storage tank. That helped a bit.. i can blast wide open and not drop below 90 psi. But its still not enough, i need to blast around 125psi. So the need for a 175psi compressor comes in.
I am the type that would rather buy something older that is well built and redo it. I found a saylor beall gas air compressor not far from me for $175. It used to be mounted on the a trailer, but the trailer was hit. From what i can see, the intercooler was hit and it snapped the connecting point on the head. The mounting brackets on the tank are slightly bent and some paint missing. The previous owner took the engine off of it... so when i bought it, it was just the tank and compressor. It originally came with a kohler engine, but i am a Honda guy!
I checked over the pump and flywheel, seems to be in good shape minus the head. It has the intercooler which is not pictured, luckily it was not harmed. I would still like to take the side cover off to check everything out. With the kohler engine, the pump was originally mounted on the left. But since i plan to use a honda engine, i need it mounted on the right. So it kind of works out that the head needs to be replaced, since i need to change the side its mounted on anyways.
I did a ton of research on here about the pump. I need the valve tool... I did a lot of measuring and I found a 3/4 8pt impact socket that i plan to modify. I measured from the outer edge of one hole to the outer edge of the other hole which was 1-3/8. The OD of the socket is 1-3/8. I am hoping to cut the edges of the socket out, leaving just 2 points. There is a lot of meat in the points... i am hoping to file the triangles down to circles. Seems like it will work perfect as long as it doesn't snap... i bought an impact socket hoping it would be stronger than a regular. If it doesn't work.. it was $10 wasted and ill just buy the premade tool.
