Scan Tool for ipad Obd2 ?
articsilber323
maryland
just got the obd fusion and this adapter
works good for what it is after you figure out how to use it and it shows mode 6 data!
you can also graph up to 4 items this is why i got it as my current scan tool didnt graph very good
bank 1 has a bad cat converter bank 2 shows a good converter
http://www.amazon.com/gp/product/B00MP6GSWQ/?tag=atomicindus08-20
Trey T
Houston, TX
I use dash command with KIWI 2 WIFI module. I bought mine for $60 but currently NewEgg have them for $25; makes me quite sad BBC I bought it 6mo ago
I primarily use it scan code and erase code
Chevy-SS
Rhode Island
How steep is the learning curve in order to look at the voltages and make your determination? Is there anything in the program that gives you some hints about how to make proper diagnosis for each different code??
Thanks ;)
articsilber323
maryland
Thanks ;)
no there are no hints it is practically just a normal scan tool that works on your phone
i just had a problem with my current scanner that it would not graph more then one pid at a time so this is a little better for me but still no where near a high dollar scan tool
Chevy-SS
Rhode Island
Well, thanks for the info. Much appreciated. :D
I got no problem spending extra money for a "high dollar scan tool", but I'd like something that is as user friendly as possible.
bulletpruf
San Antonio
I use Dash Command with my iPhone. Fairly easy to use.
Scott
