ScepterToad
- Joined
- Nov 9, 2023
- Messages
- 340
Well, another weekend down and it was pretty decent. I spent less time at the shop this weekend (which I don't really like), but I got some down time both mornings, which I needed. Saturday I spent the morning drinking some coffee and watching This Old House. I love that show. Headed over to the shop to button up the bathroom project on the coach. I started with the two end "backsplash" pieces on the countertop. They were originally put on with silicone adhesive, which is what I used to put it back on. I cut some small pieces of 1x2 and used them to push on the corian parts with a bar clamp with the ends turned around. Unfortunately, it was on an angle. More on that later.
From there, I moved on to the wood case that sits over the cable/waterline chase at the bottom of the outside wall. It's two pieces and once I figured out how it went back in, I was able to get it cleaned up and in place. Again, secured only with one screw and some silicone adhesive caulk. The wall was a little out of square, which created a small gap in the corner. However, once I got it caulked in, it looks pretty OK. The second screw had broken off when I pulled the parts, so I didn't try to put it back in. I'm not sure how that will work out long term, but I'll keep an eye on it. After that went in, I moved to the corner cabinet and piece of "crown molding" that goes in on the outside wall. Cabinet is screwed to the wall and the crown is glued on. I also tackled the TP holder and towel holder. Easy Peasy.
Final piece for the day was the window. I didn't realize when I pulled it out that it has a rubber gasket around it and not butyl tape like a lot of camper windows have. I managed to cut it while removing the caulking along the top of the window. Given that, I opted to seal the entire window. I laid a bead on the rubber gasket and pressed the window in. Securing it inside with the 13 or so screws that make up the inner frame. From there, I sealed it up along the outside edge with more silicone caulking.
Yet to do is the dryer vent and some small trim pieces along the floor, which are siliconed on with small pins (not brads). I ran out of silicone, so I couldn't finish up. That worked out though, because my buddy called with a problem tractor stuck in the field. One of the guys had been bush hogging and it just died. He's not much for maintenance on things, so the phone diagnosis was a fuel filter (which probably hasn't been changed in years, if ever). Got to the tractor, cracked the bleeder screw after verifying that it had fuel in it and there was fuel coming out. Ok, not a filter. Cracked an injector line loose and nothing. Ok, injection pump INOP. Turned out to be the shutoff solenoid wire was loose (spade connector) causing the injection pump to not push fuel. Rigged it back on and sent him on his way. He can deal with putting a new connector on.
Sunday, was a lot of the same in the morning and then went to see my folks. I hadn't seen them in about a month and they're getting up in years. Any time I can get with them is appreciated. My dad has two barns FULL of stuff and his health is not great these days. All that stuff will go to me at some point, so he's trying to unload a few things here and there now. Stuff he'll really never use. There are a few items that he's eyeing and they'll be a welcome addition to my collection of tools. More on that later. For now, some pics of the bathroom remodel.
Bead of silicone for the "backsplash"
Rigged up clamp
Towel holder. I'm really starting to like this wallpaper.
Half of the base that sits over the utility chase.
I had to take the cap off to expose the screws.
Removed
These scrapers work really well for removing old caulking. Just have to be careful as they'll dig in pretty easy.
Just out of square. I wasn't expecting the the walls would be square, so this wasn't a surprise.
Test fit.
In with the caulking sealing up the joints.
More to come.
Rigged up clamp
Removed
Test fit.
More to come.
