School me on corded reciprocating saw
metaldad
nw indiana
you can find any brand and model on ebay, to fit your budget. research that parts are available
milwaukees were the standard, when they were made here. stroke, depends on what your main focus on cutting is, wood or steel. however, for steel, a grinder with a cut off wheel is usually a better choice.
by my experience, and ownership, all on older saws,the following:
the sawzall itself, well balanced, resulting in less operator fatigue. power runs the spectrum, as they were made in a wide range of models. the qwik lock cord is nice. including a 18v fuel, which isnt as ballsy as the corded ones, i have 4
porter cable tiger saw - the most powerful saw i have, but, not as well balanced as a milwaukee. i have 2
porter cable tiger claw - verastile tool that has an infinite range of tool/blade alignment. gimicky, i have 2
porter cable tiger cub - one handed tool. gets into tight places. some parts no longer available. i have 2
bosch - whatever model i have, didnt come with a cord, just the prongs you plug an extension cord into. not a fan, as the cord tends to vibrate off. i have 1
milwaukee 12v hacksall, pos homeowner garbage.
don't like starrett and de walt blades.
csp
Franktown, CO
My pawn shop Milwaukee has been treating me right for at least 20 years. It's in a metal case and doesn't have the quick connect blade system, so who knows how long the previous owner(s) had used it.
mike93lx
Richmond, VA
Quick connect is an awesome convenience feature. I wouldn't pick one up without it today
Al Borland
If you are a meathead who will try to force the tool to cut, the DeWalts eat their bushings and then the blade release doesn't work.
I have dozens of meatheads at work. They can destroy a DeWalt in a day.
And the office do-nothing/know-nothings keep ordering more...
And HIRING more meatheads.
I've watched said meatheads "Bayonet" ductwork to start cuts.
Yeah, the blade clamp is a weak spot on my older ones. The blade clamp system is considered a disposable part. I keep 2-3 screws and and extra clamps in the box, the allen wrench is magnetically held to the lid. Anything to avoid going to get a different saw out of the garage.
CJM8515
I like milwaukees better, but I couldnt pass up a free dewalt one. wish it was more powerful as the 6amp one i have is older and so so. but with how often i use it its not a big deal. diablo blades are all i use, i tried some milwaukees and they ****
mercifiknow
Somewhere I should be
Agreed about the angle grinder for metal but there are times when it would’ve been easier using a “sawzall”.
what did you means “parts available”?
metaldad
nw indiana
parts, are parts. switches, bearings, guides, brackets, electronic boards
i rebuilt 2 tiger cubs, bearings no longer available. pc used needle bearings. i was able to use ball bearings
had a newer version of milwaukee. parts cost more than a new one
and, to tell the truth, a recip saw i really dont use anymore. mainly for caping out fittings, and yard work. for metal work i usually grab a grinder, band saw, or torch
Downwindtracker 2
BC
Maybe. I had a Milwaukee skilsaw that that dated from the early '80s, i took it into our very good local tool repair shop . It was "Sorry we can't get parts." A Makita skilsaw from that same time frame had just got repaired. That was before this disruption.
Jswain
Calgary, AB
The nice thing about a Milwaukee SawzAll is you can get parts just about anywhere. I inherited a 30 year old one. It even survived being underwater in a flooded basement for a day. After another 20 years parts inside the gearbox finally wore out and it was an easy fix.
The even nicer thing is everybody sells their corded models for next to nothing when they make the jump to cordless.
Aaron_W
Another vote for Milwaukee, although mine is probably 10+ years old so can't speak to what is current. A nice feature on some of the higher end recip saws is you can rotate the end allowing you to cut upwards or sideways without rotating the grip.
Some of the other brands are lighter duty, but if you are just looking at occasional use vs daily use demo-ing a house I don't think you can go wrong with any reputable brand.
If you look for an used one, the 1/4 turn quick release blade change is a nice feature that isn't on some of the older saws (15-20+, not sure when they added that feature). Much nicer than using a set screw.
sparky 1971
Central Iowa
I have a Black and Decker industrial, Porter Cable tiger saw, Milwaukee, and a Hitachi. They all work equal except for the fact that the Porter Cable and Hitachi have the orbital action selection. Those will cut wood like a banshee. It's been over 10 years since any of them have been touched. Went cordless and never looked back. If I knew where you lived, I would offer to give you one just to clear shelf space.
Terry D
St. Louis, MO.
Same here. I couldn't tell you the last time I used a corded one.
How long ago? My circa 82 was refurbed about 10 years ago, many of the parts from newer models seemed to be the same. Not switches, but brushes, the depth of cut thing, rubber boot, and a cord boot I think. Ereplacementparts.
wonder if gears etc are close enough to gamble. Little rework, and away you go.
Ton ton
Page County,VA
This saw will get in places most recip saws could only dream of.
I have not seen something like this in real life. You ****.
mercifiknow
Didn’t know people repaired them or they were easy TO repair.
learn more on this forum everyday.
Iron Beaver
Here is my opinion:
Pre-TTI Milwaukee are king. But, in 2008 I had a post-TTI Milwaukee "pro-grade" sawzall that was the biggest hunk of junk ever. TTI cheaped out on the wiring and connectors and a wire or connector in the motor would burn up every 20 hours or so of use. I fought that thing for years on end and I am now a Milwaukee hater for ever. That said maybe TTI has learned a thing or two in 13 years.
This one https://www.makitatools.com/products/details/JR3070CTZ is probably okay-ish.
If you want a real pro-grade reciprocating saw, try this one. It will make Makita, Milwaukee, and Dewalt tools look flimsy and inadequate.
Downwindtracker 2
BC
I replaced the saw with another Milwaukee. I like having two skilsaws. The replacement was a very different Chinese. The American made one was a post adjust, with lots of magnesium and the Chinese was the much more common pivot adjust, with lots of grey plastic.
csp
Franktown, CO
Indeed it is, my cordless DeWalt and the Rigid at my other home both have it. You'd probably be hard pressed to find a used sawzall these days without it. My old Milwaukee has still cut 5x as much as the other two combined.
BlueWho
I've been considering getting a corded reciprocating saw for some heavier demolition work. If I get one, I've been favoring the Skilsaw 15 amp corded reciprocating saw. It seems to have both excellent power and vibration control at a comparatively reasonable price. It's slightly above your target budget, though there is a 13 amp model that is well below that limit.
I may also just get a high end cordless one, but they still don't seem to have nearly as much power or quite as good of vibration control. It'll probably depend on what has the best holiday sale.
GTO
NJ,FL
The nice thing about a Milwaukee SawzAll is you can get parts just about anywhere. I inherited a 10 year old one. It even survived being underwater in a flooded basement for a day. After another 20 years parts inside the gearbox finally wore out and it was an easy fix.
Mine was under water too in Super Storm Sandy in '12.....still works like a champ. Had to throw out my Skil Circular saw that was also under water.
TJMtl
Montreal
I have the big orbital Milwaukee corded for big jobs, usually use my M12 Milwaukee for small odd jobs, usually with hacksaw blade.
Maui
Upstate NY
Buy one at a garage sale for $10 or $20. I bought a corded Stanley Black and Decker at a sale for $12.50 when I was unable to locate my Milwaukee, and it has cut everything that I’ve asked it to so far without any problem.
Mark in Indiana
Southern Indiana
I’m looking to buy a reciprocating saw. (Not Harbor Freight). I will be doing the typical things with it, like, projects around the house and automotive projects.
I’m not looking for great blades to use with it as well. Price sub-$150. Not sure if I’m missing any information to give you all.
thanks!
Regarding your HF reciprocating saws: 20 years ago I bought a Chicago Electric (sold by HF), for $19 to cut out a wall section for a doorway. It did the job. Since then I put that saw through Hell. Cutting steel basement window frames, pruning trees, various home repairs, etc. Even used it 2 weeks ago to cut out part of a sub floor at my son's business. The only problem I had is some of the case bolts came loose. I just replaced the missing one and thread locked the rest. I'm not a cheerleader for HF. However, in my experience, this saw is the best bang for the buck. My experience with blades: I've found that better quality, not top $$$ or trash is the best way to go. Unless you're going to destroy a blade by cutting flooring that has nails / screws, then get a bow of "disposable" blades.
mercifiknow
My philosophy of HF has changed considerably over the last few years. While I agree there are some quality tools there, I got tired of spending my money there and lasting either once or not even finishing the job. The final straw was not one but, two faulty jack stands. I try VERY hard to by vintage or antique American made equipment, tools, or things needed here at the house. I like being on Garage Journal and won’t comment on much more than that.
Thanks for your input and IS APPRECIATED!
Ingram306
I have an m18 cordless that does about 90% of the stuff I need to, such as a few cuts here and there. For big demo jobs I have the 15a corded super sawzall and it’s a beast. Rips through everything, but it’s noticeably heavier.
