If you are considering electric, Foredom is very popular.
I would recommend if you use it everyday oil it everyday...... and IR makes really good stuff reasonably pricedFuji is good quality. Japanese Industrial. It is standard issue at all Japanese Automotive manufacturing die maintenance and equipment maintenance departments. If you use a cut off wheel higher RPM is better. Always wear eye protection. 24 to 28 thousand RPMs is good. Keep in mind most cut off wheels on the market are rated for 25 Max. Put five drops of air tool oil in it once a week and it will last you a long time. I was going to buy a souix by Snap-on made in USA on eBay but it was front exhaust. Rear is better for me. Fuji has a filtered rear exhaust.
Isn't Foredom for small stuff, l think it takes 3/32 shaft bits. It is sort if a big boy's Dremel. I think we are talking about 1/4" shaft bits. There are in-line electrics from DeWalt, Makita and the other power tool companies in various powers. I have an old Makita that is not their most powerful and it has not been too bad.If you are considering electric, Foredom is very popular.
For fab work I use 12,000 rpm die grinders. More torque and better low speed control. There's no reason to spin most abrasives at 20k or more. For 90 degree grinders, I prefer the geared heads to the air driven (turbine) heads, which sap power.
I have one 20k straight die grinder, as some carbide burrs like the higher revs.
My 90s are 2 .4hp Dotcos a .4hp Dynabrade, a .7hp Dynabrade and a bad *** 1hp Sioux. Straights are a .5hp Dotco, .7hp Universal Tool and a 20k .5 hp Dynabrade. I also have a mini 20k straight, i forget the brand, name wore off it years ago.
Once you use professional grade air tools you won't want the cheap stuff any more. There are great deals on ebay, if you have some patience.
They have collets from 1/16 to 1/4.Isn't Foredom for small stuff, l think it takes 3/32 shaft bits. It is sort if a big boy's Dremel. I think we are talking about 1/4" shaft bits.
