kbuhagiar
Hello Folks,
We recently purchased a new (to us) house in Escondido, CA. which has an electronically-controlled sliding gate at the end of the driveway. I've never had experience with an electronic gate before, so this is all new to me.
The gate opener is an All-O-Matic and was installed sometime around 2001. It has a separate touch-pad controller box and currently the only way to open the gate is by entering a 4-digit code. The previous owner left notes about how to change the code (which I have already done) but little else. There are no remote controls. The gate action is somewhat erratic (occasionally re-opens upon closing or sometimes stops mid-stream) and will probably require some service, but before I start pouring money into service visits I would like to establish what I have and whether I should consider upgrading to a newer model.
To the garage door/gate experts here on line, I have some questions:
Is the All-O-Matic product considered a quality brand? Should I keep what I have and just bring it up to snuff? Or should I look into upgrading with something more modern?
Are the control pads proprietary, or will they work with any brand of gate controller?
Would I be able to upgrade the control pad to make it Wi/Fi compatible?
Are there any add-ons that would allow me to control the gate through wi-fi or at least with my garage door controllers (Liftmaster using the MyQ app)?
I don't want to replace a perfectly good controller that just needs some adjustments, but if the maintenance/add-ons start adding up I would rather consider upgrading to something newer that has some newer features.
I am a competent mechanic with an IT programming background so I am also perfectly fine with maintaining & programming the gate myself...is there anything about these devices that requires intervention by the professionals?
One more thing...how do you open the gate during a power outage? Power was out yesterday for about twenty minutes and the thought did cross my mind.
Thanks in advance for your thoughts and observations!
