atch
If I put three 3,000 lumen LED lights inside my blast cabinet does that total 9,000 lumens or something less?
Neither.If I put three 3,000 lumen LED lights inside my blast cabinet does that total 9,000 lumens or something less?
It means put one and see if you can read the small print on a can of spray paint. If you can't, add another one. If you still can't, add the third one.
It looks like we were typing at the same time. So the short question is will 3 lights make it brighter in the cabinet than one or two? Logic says it will but does light brightness follow logic?Neither.
It doesn't really work that way. Adding them together doesn't mean anything or offer you any more information that's useful.
All you would have is 3 x 3000 lumen lights.
Stated in layman's terms, lumens is simply the measure of how much light a source is producing. It's nothing more.
Knowing how many lumens you have isn't really very useful information except for comparing light bulb A to light bulb B. Back when we referred to light bulbs by how many watts they used, you knew that a 100w light bulb was brighter than a 40w light bulb. Today, you know that a 1500 lumen bulb is brighter than a 400 lumen light bulb. Adding all your light bulb's lumens together doesn't really tell you anything.
CD
Ok; thanx.
I'm only going to jump through these hoops once. I'm not going to muck with this thing twice or three times. I'll just put three in and see what happens.
All I've got to lose is some ca$h but it won't take much more time to put 3 in that it would to put in 1.
Note: there's room for 3 24" LED lights but I don't think I could get a 4th one in there. One between the glass and the gloves and 2 at the top of the cabinet.
I'm doubtful that the one between the gloves and glass will help much in that the gloves will probably block most of that light from hitting the project piece. However, that light might bounce around (reflect) inside the cabinet and still be useful.
Lumens are a measure of the light produced and taken at the source.
Foot Candles are a measure of the light taken where it falls.
That is as I understand it, I maybe mistaken.
