Last year I ran the gas tank dry and filled the pump with RV anti freeze on my 20+ year old Excello pressure washer. Today I put gas in it and the old Tecumseh engine fired on the second pull. The spray pressure was pretty weak so I disassembled the wand to find that the plastic pieces inside have reached the end of their life.
My search for a replacement wand begins. The original is an Italian unit with with a twist nozzle to change the spray pattern. I can use that or a changeable tip. The wand is about 3' long.
The pump only puts out 2000psi but it has worked well for my use.
A quick search shows a dizzying array of options, I suspect that since I have a low pump pressure I could narrow my selection considerably.
any suggestions on what to look for?
