ProCharger
- Joined
- Feb 2, 2015
- Messages
- 69
Let me start by saying I have a ton of normal combination wrenches and while I am quite happy with them I am wanting to add ratcheting wrenches to the mix. Having no real experience with them I dive right in and start researching. Please feel free to correct me anywhere my assumptions are incorrect.
With that said it looks like a regular ratcheting combination wrench is your basic open jaw and a ratcheting box end that is usually straight with 0 offset. So am I right to assume you must flip the wrench to change directions? With 0 offset due to the having to flip the tool to change direction to me sounds like possible clearance issues on flat areas...not for me...pass.
That brings me to the reversible wrenches. These are appealing due to usually having an offset to raise the tool off the work area for better clearance and no need to flip the tool for a direction change. Does that sound like an accurate description?
Last I have been looking at flex heads. Easy enough, head pivots on an axis allowing more versatility over both standard and reversible.
Am I missing anything in the differences between reversible and flex head? Am I right to think the flex head offers all of the pros and none of the cons over the reversible while adding more uses?
Im not in the market for anything top of the line but I have been looking at Gearwrench brand for most of my comparisons so far. I am a hobbyist with a ProCharged S-10 in the garage I mess around with once in a while, definitely not using in a professional setting.
Is there anything else I should be looking at when considering ratcheting wrenches? Right now I am leaning towards a set of sae and metric flex heads, something like Gearwrench 9901D and 9702D. Any help/guidance is greatly appreciated.
Pro
Pro
