School me on these...
allinon72
Indianapolis
They are good for heating up a bolt to remove. Not an extremely stuck one though, as it can't get it red hot.
koditten
Midland, Michigan
If you opt for the MAP gas version, you can get any bolt red hot quickly. IMHO, get the MAP gas for this tourch. Not much more money and it last a lot longer because you can get whatever you are heating hot much quicker than the standard propane cylinders.
You might not use this tool often, but when you need it, it is there.
Greatwhitewing
I would SECOND going to MAP gas. There is a version I recently bought that has flame adjustment knob to throttle back if it's too hot.
littletoes
NE Washington
That one *****...even for a home-owner. Try this one, its much better, and can be found for around $60.00, if you look.
Just make sure you get the version that will work on Propane OR MAPP, that way in a pinch you won't get "stuck" when you need it.
http://www.buyplumbing.net/STK99-Turbo-Torch-STK-99-Extreme-Hand-Torch.html
I've been using one of these off and on for 20 years, I've even soldered 6" diameter copper pipe with it, just to see if I could.
The igniter is getting a bit week after 20 years, so I guess I can't complain, but it usually still ignites after a couple of tries. The "all-position" tip is awesome.
Here it is direct from the manufacture;
http://www.thermadyne.com/turbotorch/products/detailProduct.html?prodID=0386-0851
Gort the giant robot
Washington State, U.S.A. Planet Earth
I use a propane torch at work all the time removing transfer cases from transmissions. Most auto makers use loctite on t-case nuts and bolts. Some of the nuts and bolts have to be removed with wrenches as there is no room to use a impact wrench. Before starting on each nut or bolt I heat them up and it makes the job much quicker.
Gort.
woody 73
The Great State Up North
When you are at work and you have a lunch Break pick up a few hot dogs and heat them up,nothing better then a cooked dog.
The name escapes me at this time but if you take two Graham Crackers and put a chocolate bar in between the crackers and place a few Marshmallows on top of the chocolate bar , then just give them some heat they are a very nice treat after your Hot dog meal.
Wash it all down with a cold soda!
I
illmatyk
Yigo, Guam
Lol..I see, thanks for all the input guys. I talked to a friend of mine and he has a similar one and said its best to get the one with adjustable flame etc etc. Maybe I'll get one this week.
:beer:
Greatwhitewing
Smores!
when you are at work and you have a lunch break pick up a few hot dogs and heat them up,nothing better then a cooked dog.
The name escapes me at this time but if you take two graham crackers and put a chocolate bar in between the crackers and place a few marshmallows on top of the chocolate bar , then just give them some heat they are a very nice treat after your hot dog meal.
joshmodelskidoo
mid western michigan
i have one of those cheap torches and a buddy of mine has the map gas version and i works freat for small stuff like bending rods,and making thinner brackets, heating like 1/2in bolts and under. u could probably heat up bigger bolts to. i really want one of those little tourches. and u dont have to haul out the big set of tourches. ihave one of each of these http://www.lowes.com/pd_124500-1387...t=torch&pl=1&currentURL=?Ntt=torch&facetInfo=
http://www.lowes.com/pd_148722-13877-312321_4294936478__?productId=3339490&Ntt=torch
got the fist one from a yard sale and it works pretty good but it goes through oxygen like crazy. the second one isnt worth a c **** except for plumbing and really small stuff
greasemonkey44
memphis
beelsr
NE PA, USA
I see no one else uses a torch to light the coals on a grill. No starter fuel taste. Works great!
grills
coal furnace (mapp)
woodstoves
coal stoves
burn barrel
I have several. My favorite is one like www.truevalue.com/product/Brass-Regulated-PropaneMAPP-Torch/18193.uts - expect mine is red plastic cased and the adjustment knob borke off years ago so I brazed a dime into the slot on the adjustment screw. I've had it since the 90's sometime and it was < $20 at Wal-Mart.
I was looking at picking up another and was amazed at the prices. :wtf:
