I have two model SE-1275A chargers. One charger has two 12 volt wires where one is solid black and the other is black with red stripe. The other has two 12 volt wires where one is sold black and the other is black with white stripe. On each of these, which wire is positive and which wire is negative. Also, when I hook them up using either 12 or 75 amp settings, the gauge fluctuates back-and-forth rapidly and after hours like this, trying to charge the battery, they still never stop ******* to the extreme left and right. One charger sparks fiercely when hooking it up as if the battery is either shorted out, or the cables are connected wrong. (and I did recently replace the alligator clips n it and may have connected them to the wrong wires). The other sparks a little when connecting but not nearly as bad as the other. Either way, the battery never charges and this happens when trying to charge three different batteries. When set to 2 amps, nothing happens and the needle simply stays to the far left. the green light stays on indicating it is charging. What is the problem here?
