greenbank
I picked up a smallish Thermo scientific oven from CL ages ago to bake enamel-painted parts in...the max 200-degree temp is perfect for that and it doesn't take up a ton of space.
My problem is this: I finally set it on the bench and plugged it in the other day, and it trips my GFCI outlet after about a minute. It does that predictably. I have a plug-in meter which I can plug the oven into, and it was drawing a steady 6.6 amps, on a 20 amp circuit.
My other problem is that every 115 outlet in my shop is protected by a GFCI. So I don't really have the option of just plugging it into a "plain" circuit, nor do I want to, I guess, if it's got an issue.
So: Is this typical of this sort of appliance, and not designed to be plugged into a GFCI, or is there something wrong with the oven itself...and if so, any good places to poke? I don't have a lot of money into this and don't plan on having a lot into it, so if it's not good and not cheap to fix, I'll move it along.
But it sure would be nice to have it working.
