I'll always raise mine up, then lower it down on the stop, then just pump up the cylinder a hair.. This way you have the hydrolic cylinder, as well as the stop protecting me... I will also use four jackstands if I'm gong to be under the car....
The operating instructions on one of the Bend-Pak scissors lifts states specifically you should release the hydraulic pressure and let the stops hold the vehicle. See below:
�� Read operating and Safety manuals before using lift.
�� Always lift a vehicle according to the manufactures recommended lifting points.
�� Position vehicle properly.
�� Insure that the vehicle is positioned with the center of gravity midway between pads.
�� NEVER use runway assemblies without rubber pads in place.
�� Raise the vehicle by depressing button until the vehicle just lifts off the ground.
Recheck to make sure the vehicle is secure and stable.
�� Raise vehicle to desired height. Lower vehicle onto nearest safety,
�� Always ensure safeties are engaged before any attempt is made to work on or near vehicle.
