saghi
I am building a 20' x 32' pole barn shop. A 24' x 20' section of it has scissor trusses that are 5:12 on top and 3:12 on bottom. They span the 20' length. The short span leaves very little room between the top chord and bottom chord. My plan was to install vapor barrier on bottom chord of truss, baffles to block insulation from flowing into the vented soffits, those foam air channels so insulation wouldn't block venting, and then blow in several inches of fiberglass. Vented soffits and ridge (only the vented closure strips not a big raised ridge vent). This will be a minimally climate controlled shop.
Since it's such a small area, I'm now wondering if I can just blow in enough fiberglass to nearly fill the area. I probably couldn't completely fill it but could put more than I was planning. I'm going to have the machine rented so I might as well do as much as I can.
If I do this, I think I would leave the soffit and ridge vents and install the baffles and channels the same, then fill as much of the remaining area as possible.
Does this seem like a good plan? I doubt I would be able to completely fill the area so it might end up being 12-18" of insulation and 6" or so of air space but my goal would be to fill it as much as possible. Due to the shape, I would end up with thicker insulation towards the middle.
I plan to attach the hose to a pole and have access from both ends of the area so I think I can do it without having to crawl into that tiny space. Trusses are 4' oc and the ceiling will be lined with 29g ribbed steel panel.
Is this a bad idea? Would having the space mostly filled with insulation create any negative issues I don't see? Is leaving the venting in place a good idea? It was never planned to be a usable space so I figure I might as well put as much insulation as I can....
