scissor vs 2 post vs 4 post lifts...
smttysmth02gt
Gulf Coast (AL)
Which one do you prefer, and why? I'm not even close to the planning stages of my build...I'm clearing the land of trees and by myself so I am a long ways away. I am curious though, why one person may prefer one type over another. The best, for versatility appears to be the 2 post IMO.
scissor - can be flush and out of the way and allows access to most of the vehicle, including wheels and suspension, however, blocks access to the mid section of the underbody.
2 post - allows clear access to virtually the entire vehicle, but is not movable and the 2 posts are clearly in the way wherever they are mounted.
4 post - allows clear access to entire vehicle, except wheels and suspension, but takes up the most space with the 4 posts but it is movable.
Please correct me if I am misunderstanding or missing something.
zkling
You have it pretty well detailed. The scissor lifts are typically for the space conscious, 2 posts most versatile lifting, 4 posts double as a means for car storage by stacking. You can get the wheels of the ground on a 4 post, but you don't gain the access as you do on a 2 post.
BeachBoy
best of all worlds:
but $$$ and requires significant installation costs (deep concrete pit)
BeachBoy
although the ability to create a work platform with the separate scissors lifts is a great thing. youc an also lift only one side for small stuff like mowers... which you can't really do a on 2 posts or in ground 2 posts.
LWW
SF Bay
You nailed it. If you don't need to raise more than 5k lbs the portable MaxJax 2-post is a good compromise since it can be dismantled in a matter of minutes and stored out of the way. It only has 42" lifting height but has clear floor and ceiling access. Works great on everything I have with the exception of my turbo diesel Ford Excursion...
The MaxJax has the option for a "motorcycle" attachment for using only one post. I built a table that I can attach to the motorcycle attachment so I can use it as a temporary workbench as well.
