ScottC's Garage Build
ScottC
Summerville, SC
I've been in the midst of my garage build for the last 4 months & finally got a chance to share progress and pics. We downsized almost three years ago to a house without a garage, so I've had all my stuff in storage while we remodeled the house and rebuilt the "garage budget".
I've had a long time to plan and have gotten TONS of ideas from GJ!! I designed the building myself, working within the towns offset requirements, codes, preferences, etc. They even require a PE stamp for anything over 700SF (good thing I’m a PE)! I've ended up with a 26x30 detached garage, with the following either completed or planned:
  • 8' stud walls on 3 courses of block (10' ceiling)
  • two 9x8 entry doors
  • 32" entry door
  • 5 high-wall transom windows
  • Hardiplank siding
  • full bath (shower & toilet enclosed, utility sink open to garage)
  • 100A subpanel
  • Phone/internet/cable
  • attic trusses
  • 4'x4' attic hoist door
  • pull down attic steps
I only contracted out the tree cutting and concrete work. The rest has been accomplished by me, my dad and a bunch of great friends. The trees started coming down on 4/26 and I've gotten this far only working nights and weekends. I’m trying to at least get the outside finished and painted before Baby #2 arrives in early Oct. The triple-digit heat/humidity is surely slowing down progress.
It took me two full days to install all the required Simpson straps (can you say bomb shelter). I’m convinced that all this metal is only required by code because everybody’s forgotten how to frame with a hammer & nail.
I'm still trying to decide what to do with the floors. I like what I've read about the epoxy systems, but I don't want to waste that $$ with welding/grinding work. Any thoughts on that would be appreciated.
Also, I still have a roll of Vaporblock 6 for sale. LINK
4/26/07: I had to have 3 large trees cut – 2 in the footprint of the garage.
5/3/07: Digging the foundation & setting forms.
5/5/07: Vapor barrier, rebar & plumbing drains in place.
5/8/07: Concrete was poured on 5/6 and the blockwork finished on 5/8.
5/11/07: Wood delivered and getting ready for framing.
5/12/07: I had 9 friends help me with the initial framing push – three walls up.
5/15/07: Front wall framing finished.
5/18/07: Wall sheathing mostly complete.
5/22/07: Trussed delivered & getting ready to lift the first one.
5/23/07: Further along with trusses. The bucket lift was worth every penny!! You can see the double trusses framing the attic hoist space.
6/5/07: Wall sheathing mostly complete, gable overhangs built, roof sheathed and papered.
6/22/07: Wall sheathing complete; facia and shingles on.
6/22/07: Another shot of the facia and shingles. Also block stucco work complete and you can see the pumphouse in the back corner (I have to pump the wastewater back uphill to the house).
7/26: Housewrap up, soffits built-out, windows and entry door installed and 5/4 treated trim going up. Garage door surrounds installed.
7/31/07: Vehicle doors installed (over-budget, but they look great!!) Clopay makes a very high quality door.
8/19/07: Front overhang supports completed and siding going up. The overhang will be finished off with green aluminum roofing.
8/19/07: Pumphouse roof and trim complete. This roof lifts off to gain access to the sump pump. You can see the potable water line in the foreground.
boiler7904
NW IN
Very nice. Looks like it will be a great space when it's all done.
As far as the epoxy floor system, I wouldn't spend the money if you know going into that you'll be welding and grinding. You'll burn through the epoxy in no time.
You might want to look at diamond polishing of the floor. Pricey but it looks good, hardens the surface, and won't be affected by welding or cutting.
wayoff
South east NH
Very nice. I did the same thing with the small windows for "security" purposes. My garage isn't finished yet, but I'm starting to wish I had put in some lager ones.
S
ScottC
Summerville, SC
Got the bulk of the siding finished up - only have to finish the pumphouse and a few pieces over the vehicle doors. All this in under 4 months. Time to start the electrical and plumbing rough-ins.
Also got my HF hoist mounted in the attic. Eventually this will be on a trolley running lengthways.
And here's a pic of the inside of the pumphouse. This is a Flotec sump pump unit - a 110V submersible grinder pump will be in the basin.
S
ScottC
Summerville, SC
The roof is a 7:12 and I ended up with a 11.5'x30' space. There is roughly 6'2" of clearance in the center of the attic.
A truss designer only needs a few variables to give you this information in a matter of minutes. I knew my attic dimensions while we were still on the phone together and had a .pdf over email shortly afterward. Garages typically have very simple truss designs.
curlyws6
Eastern North Carolina
You have a nice looking shop!
I wish I had built in a bathroom in my shop. I didn't bacause of having to install a pumping station to my existing septic system (didn't understand hoe it would work and was too hard-headed to ask :wtf: ). My future plans are to build a small addition on for a bathroom.... it would be very nice to have when throwing parties.
S
ScottC
Summerville, SC
I don't have any project updates, but had a question about the front metal overhang. I'm posting some pics of another local "carriage house" and metal roofs that I drew design details from.
burger
Erf
Boiler: I sent Scott a PM asking how he was going to finish the roof above the garage door. His garage design and mine are very similar... I might "borrow" his idea for the roofing! The metal roof looks great and would really adds to the Arts and Crafts carriage house feel.
Ed
elvee
Atlanta, GA
If my framing crew was a bit further along, I would post what my wife and I are building. Similar idea to these, though a bit taller. The architect we worked with made it very much a craftsman look carriage house. I'll see if I can reduce the size of the pdf's of the front to give you an idea. Otherwise, wait about a week and I'll have a thread started with what we're doing.
S
ScottC
Summerville, SC
No updates in a while, but yesterday I passed my electrical and plumbing rough-in inspections. I've already hooked up the electrical and am busy filling the two trenches I have across the yard. Just have to sheetrock the bathroom and set the fixtures and I'll be ready for Final Inspection.
Fortunately, I've had a great experience with my town inspectors. They've appreciated my work and have passed me even with minor "to-do's" (e.g. - strap down water heater). I guess I should count my blessings after reading some of the permitting/inspection horror stories others have experienced.
I'll get some updated pictures later today...
dipper
Rochester, NY
Nice Job and can't wait to see the next update. I too have had a very good experience with my inspector's. I find it kind of nice to have them stop by and praise the work the I've been doing on my build. It's always nice to be on their good side; otherwise they could cause alot of pain and suffering for some people. :)
73survivor
Mcveytown, PA
Great job so far! Please give us as many details as you can on the bathroom. I'm going to be building a garage in the spring, and I didn't think I could put a bathroom in because it is downhill from my house. How far will it pump uphill?
What size of pipe did you use? I would greatly appreciate any info you can give! Thanks in advance.
S
ScottC
Summerville, SC
Here are the promised pics. I started my trenching with a rented trencher. Worked well except only one drive wheel worked and I had to wrestle that thing to keep a straight line. Ended up with two trenches - one for electrical feed and the other for wastewater and potable water lines.
For those interested in the wastewater pump, here are some pictures of the final product. The pump is in its own pumphouse adjacent to the garage so that if it fails I don't flood the garage (might add a high level float switch to indicate pump failure). The pump chamber is vented via a 2" line and has a 2" discharge line. Also there's a required checkvalve to prevent backflow from the house. I'm happy with how this system has turned out - worked great during the "garden hose test".
And here is a current pic of the bathroom. 32" shower and toilet in the enclosure and a utility sink on the right side open to the garage. There will be a pocket door tucked alongside the shower enclosure.
S
ScottC
Summerville, SC
I had a pretty productive weekend. Aside from getting the bathroom drywall hung, some friends of ours that are moving gave us their full size "garage" fridge. Guess I'll be running another water line for the icemaker... :thumbup:
Also, I found a HF bandsaw on Craigslist for $85. The owner was also throwing in 2 new Enco blades. The guy was restoring a Amphicar, so I got to look it over pretty close.
I couldn't pass up the deal on the saw and on the way to pick it up, I saw a neighbor moving out that had piled up bunch of stuff on the curb. Surely the TV out there was broken, but it fired right up!!! AWESOME - somebody pinch me!!
burger
Erf
Scott,
Looking good! I jealous of your $85 bandsaw score.
This weekend I built some knee braces for my garage that look suspiciously like the ones under your overhang. Thanks again for the idea.
Ed
S
ScottC
Summerville, SC
Had another milestone on Friday - passed my final inspection. He was probably here less than 5 minutes. It was another "if you're happy, I'm happy" inspection... Fine with me!!!
andyj
Great looking garage, great attention to detailing..
looking forward to more pics
:thumbup::thumbup::thumbup:
