Scrap habits
andyvh1959
Green Bay WI
I built my shop garage in spring of 2020, and I still have piles of left over 2x4, 2x6, plywood, etc. I have a scrap habit,....meaning I hang onto pieces of scrap dimensional lumber, lots of them. I need to set a standard, like, less than 36" long scrap the damn stuff. I need to load up my trailer with all these pieces of dimensional lumber and sheet stock and take it to the Green Bay yard waste site. I can take all sorts of scrap wod there.
I don't have a fire pit so that is not an option to eventually get rid of the stuff. So it needs to go. I'm sure there are others out there like me. If I have not used the sections of lumber in two years I simply need to convince myself it has to go.
u2slow
BC
I hang onto pieces down to 10-12". Can always make cribbing stack-platforms. 16-24" makes good shelf boards. Lumber is expensive these days.
It pains me to dig into a fresh 2x4 to make a 'scrap' for a random task.
I burn in the yard too... no fancy fire pit.
Walkers
Cave Creek Az
I just cleaned out my dads garage. My mother had us stack piles out lumber next to the driveway and she would list it on one of the neighborhood sites in the free section. We did it several times, and the stuff was always gone the next day.
rktinc
Midwest/USA
Well, I have a very similar problem after building my shop out for the last year and a half. All beautiful used lumber I just cant bear to trash. Yesterday I stopped by my elderly neighbor who has a wonderful wood shop in his back yard. He builds little projects and sells them or gives them away. He jumped at the chance to take these scraps.
I trashed the smaller ones and still have a couple loads to go. It is just so hard to clear it out but it has to be done.
rsanter
visalia ca
I have a bunch of dimensional lumber cut offs.
12” to 16” I save it.
I use it as cribbing, or blocking to beat on, it if I need t cut something out of them.
They get neatly stacked on the shelf and they get used (or given to a friend that needs one)
niget2002
Josephine, TX
I've gotten a whole lot better at judging how much stock I need for a project. Most of my scraps end up only one or two feet. I have a few small buckets that I put scraps into. When they're all full, I haul them off to the edge of the property where I put them in a pile and let them decompose.
MushCreek
Upstate South Carolina
What's annoying is that right after you purge, you're gonna need a 12" piece of this, or a plywood patch or gusset for something. Now that I'm finishing up building my boat, I have lots of scraps of cherry, mahogany, and marine plywood. That goes on top of all of the building materials left over from building my house...
Once in a while, it pays off, though. For building the boat, I had to first build a strongback and temporary molds. This all gets thrown out after the boat is done. I had about 90% of what I needed already on hand. I even saved some of the bigger pieces when I took it apart. Of course, the downside is managing all those piles of lumber while you're waiting for a purpose to come along.
Natty Bumppo
Savoy, MA
I always keep a small stockpile of scrap KD and PT 2x material and 1x pine boards. Besides that, no...I keep nothing. KD Cut-offs get cut to length and split and thrown in the kindling box. Eveything else goes in the yearly burn pile out in the back 40.
mwalsh9152
I constantly build the same things over and over, so I know what size scrap pieces I can use. I was starting to get overwhelmed by 12" 2X4's but I am in the middle of a run of builds that use 3 of them per, so I knocked that pile down to almost nothing.
This winter I will need to focus on better organizing my 225SF shop. My #2 issue is scrap storage.
Mike65
Horse Pasture, Va.
According to my wife I cannot throw away any wood scrap lumber & she is probably right. It has to be a very small piece for me to toss it in the scrap bin.
couch67
Ontario Canada
My limit is 1' or longer - BUT if I already have a few that are 1', then the new (or worst looking ones) go in the trash. I pretty much keep anything that is 2' or longer (still working on that though!)
laser3kw
northen IL
for 2x4 and similar, I use 5 gallon buckets to store them. I use them a lot as cribbing when I need to block up a mower or such.
Other times, you just need to "clean house" to get rid on stuff that you haven't touched in over a year. I'm doing that to our house much to my wife's objection (very loud objections)
Garcky
Twin Cities Metro Area, Minnesota
You need a fireplace. What you have there is kindling. That's how I used my cutoffs.
CoogarXR
Or just a generic backyard fire ring. I have a 20" dually ring that I use as a small fire ring setup.
Before I had that, I just threw my tiny scraps in a tub. I would take the tub camping and burn it there.
Prospecter
Maine
Yup. I have two wood stoves. If it looks like firewood / kindling, it goes on the stack. If it's junky, it gets cut down to size and goes on the stack. If my accumulation of scrap exceeds available storage, I thin the herd.
speed bump
Butte Montana
Growing up with a dad who was a bit of a lumber horder I now take great pleasure in throwing out scraps. I still have a lot of them but when I'm cleaning up oddball pieces or real small stuff just goes if it hasn't moved for a while. Some days it's as satisfying to organize and clean a space as it is to build something with the material.
jar944
Northern VA
I keep some hardwood falloff around that can be run into moulding (usually 4' min) but construction lumber gets burned or taken to the dump asap.
Toomanytools?
Washington
I feel your pain. I have been a General Contractor, Carpenter, furniture maker for 40+ years and always hang on to stuff for that next project. Some of it might be 1 1/2"x1 1/2"x6" exotic wood that I'm sure I will use "someday". So now anything less than 24" common species get burnt or tossed. I have been hanging on to about a dozen 24-30" / 6"x8" pole barn cutoffs from my shop built 7 years ago, finally tossing them. I am a pack rat of material, you just have to toss stuff as you build something.
Jim_No_Garage
Millington NJ
All of my offcuts end up in a "deck box" that holds my firepit kindling. I have pulled wood back out of the "box" to use in a project as needed.
Jim
PCustoms
VT
I have a divider wall in my shop that is framed 25" o.c. and has 2x4 shelf supports (that were likely scrap, lol) coming off it. Scrap long enough to span supports goes up there.
Plywood goes into the stud bay, or on rare occasions I have larger they lean against the wall mostly vertical.
Short scrap goes in a box under the miter saw. Clean wood that is around 12" eventually goes into a kindling box for heating season.
When the box is full I check for anything useful looking, I might save chunks of 2x4, otherwise the whole thing goes in the campfire. Note: PT cutoffs less then 12" go straight into the trash can.
Garcky
I had a lean-to storage thing at the back of my workshop. Had walls, a roof, and doors at both ends. It was well ventilated. Long full-width shelves, accessible from either door, about 12" apart. That was my scrap wood storage area. Typically, if I was doing a project, I'd buy extra materials, so I'd be able to replace something I screwed up on. So, there was a lot of that excess wood in there. If it was less than 12' long, it could get put in that lean-to.
That was my spare lumber. When I needed something, I'd pull it out of there. Worked out pretty well for me.
nadogail
Coronado, CA
I too have a "Lumber Yard" it is the 3 foot setback between the garage my workshop is in and the Property Line Fence. The "shelves" are scraps of steel welded to the supports holding up the fence.
James-W
Southeastern Wisconsin
I don't keep any piece of wood less than 12 inches long. I cut them into smaller pieces and throw them into a heavy duty cardboard barrel and when it is full a friend of mine takes the small pieces of wood and burns them in his back yard. He has a burning pit and he has plastic chairs and he and his grand-kids toast marshmallows and have a grand old time.
bdbecker
Iowa
What has been working well for me is to have a set amount of space used for material storage. I allow myself to save whatever I want, regardless of size, until that space is full and starts to overflow. Then it's time for a sort.
Small scraps go into two plastic totes - one bin for plywood, the other for boards. These get emptied out fairly frequently. I'll keep a handful of the pieces that have the best chance of being reused sometime in the future, the rest goes to my Dad to use as kindling for his fireplace (empty dog food bags work great). I try to remove at least 75% or more of the material out of the totes when I sort them. It is pretty easy for me to part ways with most of what is in the totes because they are such small pieces.
I also have wall racks and a swing out sheet goods cart for larger pieces. I can usually go a couple years between having to clean out this area. Anything I find in this area that I don't think I'll use gets donated to the ReStore. I'm much less aggressive when sorting this area. The main goal is to get the material that I do keep back on the racks/in the cart in a somewhat organized fashion with some room left over to store material for the next project I'm working on.
I do keep a small, dedicated assortment of 2x4's and 4x4's for utility use. When I go through my totes and find a good chunk of 2x4, I'll toss the worst of the utility pieces. Every so often I'll have to pull out a good piece of wood off the rack and cut it up for utility use, but that happens infrequently enough that it doesn't bother me.
Jgaz
I too use the two tote method for small scrap. Mine are six gallon milk crates.
One is more common pieces and the other is hardwood scrap that may become a box or small project.
Lately, I have been saving more small pieces of Baltic Birch plywood then in the past.
That material has gotten crazy expensive even compared to other, inflated, lumber prices.
rdoty
Massachusetts
I built a materials storage cart to hold both sheet materials and cutoffs. The base is 2' x 4'. The stair step slots on the left make it easy to sort cutoffs by length and to get to the shorter pieces. A chain (not shown in this picture) around the sheet stock keeps them from falling off of the cart.
If it doesn't go in the storage cart it goes in the trash. At the end of major projects I sort the remnants from the project against what is in the cart and save the best. This way I have both a reasonable assortment of materials to work with and a manageable amount of materials saved up.
The only problem I have is that I used cheap casters. This cart gets heavy quickly and I really need to put better casters under it...
Notgrownup
Snow Hill NC
I also have a similar problem/habit but I make frames for my wife so anything odd size can be reused but I started to burn or trash very small pieces. I have a pretty decent rolling rack and my good hardwood goes in the ceiling rack
PCustoms
VT
Been framing a shed and ripping rough cut pine. Raining so doing some cleanup
Sweepings going in outdoor fireplace
Saved for wood stove kindling
I've also got a bunch of 2x4 cutoffs, might save the longer ones for wood stove (the don't split well though) and toss the rest in fire pit.
kwb
PNW
I have a pallet that I put ~12" sides on. Stuff in it gets used for cribbing, cut down in to parts for welding jigs, or if a small project needs something I can usually find something in there to use.
Once they start getting too busted up I throw them in a bankers box and use as kindling in wood stove, chiminea, or the big fire pit.
