Screw bits
daddycreswell
Middle Tennessee
Need help, do all screw bits have the size on them? I was trying to fins a #8 bit today and had no luck, everything I found had a 2 on it, so either I have a **** load of #2 bits or they are not stamped on them. If they aren't stamped how do I tell the difference? Thanks
Sent from my dumb apple products my work makes me use.
gregtwojeeps
Ky
The screw bits will be labeled on the new box what they fit and will be stamped for size most of the time. When a person buys the "bin sale" packages of screw bits, then they are not always stamped for size. If you are using a #8 gauge screw then most likely you will need a #3 driver phillips bit. jmo
Bondo
Greenfield, Maine
Ayuh,.... What the 'ell is a #8 bit,..??
MFolks
Springfield Mo.
For most Phillips screwdrivers, the # 1 will do the #4 screws, the #2 will handle the 6,8, and 10 size screws. #3 might do the larger 1/4", and #4 will do the 5/16" type fasteners.
