Screw Grab Friction Drops
scubadoober
I was poking around on Bondhus and saw this. Screw Grab Friction Drops Does any one have any experience with this stuff? It sounds kind of gimmicky, but just cheap enough have around just in case. Part number 94205 for reference.
bonneyman
Desert SW
I read an old school recommendation that said use valve lapping compound on partially stripped screw heads. Found a little jar at an estate sale but haven't had any bad screws to try it on.
Maybe just having it around has prevented me from screwing up any screws? A lucky charm? :lol_hitti
Coach James
Sandhills of North Carolina
Now in keeping with GJ tradition, does it matter what grit compound you use? Coarse or fine better?
Coach
bonneyman
Desert SW
Coach
When I picked up the jar I have I wasn't aware there were different grits. I suppose a coarser grit would work better (more "cutting" into the surface), but I don't know for sure.
I'm not praying to strip out a screw just to try the stuff because with my luck it'll be a do-or-die situation.:shocking:
homebuilt burner
central Wisconsin
I have used it. It works great. Maybe to good. Your screwdriver will break before camming out.
The trick is as soon as the screw starts to cam out stop and put a drop of screwgrab onto it. Then wiggle the screwdriver lightly to kind of seat it into the compound. Then turn the screw out, or break the screw head off, or break the end of your screwdriver off.
