Screw help
RedRabbit
SoCal
These bolts came included with a bench, but they are too short. I was liking for something 50 or 60mm but I can’t find the right diameter. Does anybody have advice? They are Allen screws and will bear weight.
jdewitt
Here!
It's a standard metric size look for m8x60mm socket head cap screws (bolts) if you want 60mm long.
whateg01
doo dah, kansas, usa
If they thread into threaded holes, measure the distance between the crests of the threads. If it's 1.25mm, then the screw pitch is 8mmx1.25mm. (Hint: measure over several threads and divide!) If it doesn't screw into anything, 5/16" may be more common for you and easier to get.
Dave
cherrybomb
Near Madison Wi.
At our Ace Hardware, especially in the metric fasteners, guys that don't understand the metric pitch,seem to toss the fasteners back in the wrong bins.Our Ace has a bolt and nut guage,check your bolt,find a nut,that mates.Now find your desired longer length bolt and check every bolt with that nut.Might save you a trip back.Don't ask how I know this.
