I recently figured out what I think is a pretty good solution for screwdriver organization, so I figured I'd revive an old thread. I too use the Craftsman screwdriver racks that gotmud mentioned previously...however, I found that for sometimes (especially with larger screwdrivers), it was a pain in the a$$ to get them out of the rack easily. So, I made some modifications to the racks - now, my screwdrivers sit securely in the rack and don't roll around when I open/close the drawer, and at the same time, they're easily removable from the rack. I've made a highly detailed and technical diagram (below) outlining the modifications - I hope everyone can follow, given the intricate and technical nature of these mods
Note - if you need the rack to be portable so that you can just grab all of your screwdrivers and go, then this probably isn't the best idea for you. I work primarily out of my toolbox and was just looking for a way to keep them organized and prevent them from rolling all over the place.
Step 1 - Cut off stupid handle
Step 2 - Cut off stupid horizontal piece at bottom of holder
Step 3 - Cut off stupid horiztonal tabs in the middle of the rack that are designed to keep screwdrivers in place when the rack is turned vertically (i.e. being carried or hung on a wall).
Step 4 - Flip rack over, open super secret trap door, pull out foam piece (forgot to include this on the diagram). Leaving the foam piece in is also an option, but i've found that the screwdrivers can be more easily inserted and removed if the foam piece is taken out.
The best part of it all is that removing the stupid handle makes the rack the perfect size to be placed lengthwise in a standard depth roll-away chest or a deeper (i.e. 16" rather than 12") top cabinet - putting three side-by-side fits perfectly into a 26" chest (see pics below).
Yeah, it's a little bit of work, but not much (I had all three cut down to size in about 10 mintes) - and at $5 each, you can't beat the price...not to mention the fact that you could get the screwdriver rack and a carpenter's pencil for about $0.60 by using the $5 coupon.
Hope this helps someone else get their screwdriver drawer a little more organized - I know it took me long enough to find a solution that I liked, but i'm pretty sure this is it
